Old 05-13-2005, 10:22 AM   #1
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Sikaflex at Home Depot?
I saw some advertised in the latest circular...but its listed under "concrete products". so I poked around on sika's website, and found descriptions of the material...compared it to what they sell at Airstream's website. I'm wondering if these 2 things are the same, and just packaged and marketed for different purposes.
it would be nice to be able to just stop by one of the 3 HD locations on my way home from work to pick up sealant, should the need arise...rather than pay 5 bucks for shipping.
anyway. Sikaflex 221 is described as "...a high-quality multi purpose non-sag 1-c polyurethane sealant that cures on exposure to atmospheric humidity to form a durable elastomer".
"Sikaflex Construction Sealant" is described as "..a moisture-cured, 1-component, polyurethane-based non sag elastomeric sealant"
Sounds like the same thing to me. what do you think? close enough?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-13-2005, 10:37 AM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
that would be nice, it would save the pre planning when you need to seal something.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 05-13-2005, 11:01 AM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
here's some links to product info on sika's website:
sikaflex 221 is what they sell at airstream.com:
http://www.sikaindustry.com/ind/ipd-...-transprod.htm
this is what they appear to sell at HD:
http://www.sikaconstruction.com/con/...er-sealing.htm
hard to see the difference.
and in this pdf info sheet on the HD stuff: http://www.sikaconstruction.com/ht-c...Sealant-us.pdf
"...apply to concrete, wood, brick, alluminum, steel, glass, tile, marble, stone, and etched pvc"
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-13-2005, 02:29 PM   #4
Images: 59
They are not equivalent. The 221 contains polyisocyanate prepolymer, not in the construction sealant. I think the 221 also has slightly higher elongation.
They're not equal, but I'm not saying you shouldn't use the HD sealant. I use what the factory used.
Old 05-13-2005, 03:26 PM   #5
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
That's a plus
[QUOTE=markdoane]They are not equivalent. The 221 contains polyisocyanate prepolymer, not in the construction sealant. I think the 221 also has slightly higher elongation."
I could use slightly higher elongation.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 05-13-2005, 05:43 PM   #6
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Well? How much was it???
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 05-13-2005, 11:55 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Oh my.
Oh you bad, bad boy!
Old 05-14-2005, 06:10 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
airstream.com wants $7bucks and change for a tube...PLUS shipping, no doubt.
HD: $3.98
Air:291
Wbcci: 3752
'73 Safari 23'
Old 05-14-2005, 02:29 PM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
Real McCoy
Austin Hardware & Supply has Sikaflex-221 at $5.47 a tube. 'Gray' is fairly close to aluminum.
My wife has stopped asking why the Vulkem and Sikaflex tubes are in the freezer. This greatly extends the shelf life of an open tube. Cap the end with aluminum foil and put it in a couple layers of bread wrappers. You can nearly use it right away (I'd worry about condensation on your applied bead if it was cold in a humid environment).
5 meter Langford Nahanni
Old 04-13-2010, 07:14 PM   #10
Ag&Au's Avatar
Port Orchard , Washington
Gold or platinum?
I just exhumed this thread to find out if there is any reasonably priced source for Sikaflex 221. Also does any one know what precious metal it contains. Is there any reasonable alternative for small touch ups?
Ken
Old 04-13-2010, 08:52 PM   #11
MDSilverado's Avatar
1977 31' Sovereign
Severna Park , Maryland
Many of the Sikaflex products are used regularly in the construction trade. You should be able to find a construction sealants specialty shop in any large city. Here in Baltimore I know there are several. Try searching a thebluebook.com in your area for sealants or check the Sikaflex site for local dealers.
MDSilverado is offline   Reply With Quote
Old 04-13-2010, 10:01 PM   #12
1980 31' Excella II
Drummond Island , Michigan
I have been using the Home Depot Sikaflex on aluminum boats and now use it on the A/S. The grey blends with the aluminum and seems to set up smoother than Vulkem. It has not failed for several years either on the sunnyside of the trailer or underneath. I had to do permanent fix to a jury rig repair on the bellypan and literally had to cut through the Sikaflex I used on the repair to remove them. Be sure to read the tube at HD they also carry construction adhesive and other Sikaflex products on the concrete aisle. Don't know about "Elongation" don't think my wife would like it anyway.
Ahzmyrah is offline   Reply With Quote
Old 04-14-2010, 01:23 AM   #13
Maniacal Engineer
barts's Avatar
Menlo Park , California
I've been using both Vulkem and PL sealant... they appear very similar; both are quite slow in curing. The PL stuff is available at the local hardware store.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 04-14-2010, 09:19 AM   #14
Ag&Au's Avatar
Thank you all for the ideas. I was getting a little frustrated running across prices ranging from 50 to 100+ dollars for a single tube.
Regards,
Ken
Motor Home Gun Laws winner On The Road... 26 08-17-2009 03:45 PM
'78 Argosy central heater motor home edmatlock Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-22-2002 11:57 PM
Any body out there?? NEED HELP GETTING IT HOME!!! Anna Our Community 2 11-09-2002 02:54 PM
New Forum Home Page! Andy R Our Community 8 10-31-2002 05:44 AM
Finally! Bringing it home... pjtaia Our Community 12 09-30-2002 09:31 PM
