Old 05-08-2010, 09:32 PM   #1
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Sikaflex 721 on roof?
Anyone use Sikaflex 721 UV on anything.I am wanting to replace some sealant on the roof.The sun has finally caught up with it all.
Would the 221 be just as good though.Seems the 721 UV might last longer but never used it before.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 05-08-2010, 10:30 PM   #2
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
If it is going to be exposed to uv 221 is a no go. I love 221 but have never worked w/721 I was told you have to order it in lg quantities. I suspect from an application standpoint not much difference. From what I have READ look into dicor, butyl tape or tremco 636 depending on the application for alternatives.
kevin
kevinb is offline   Reply With Quote
Old 05-09-2010, 07:17 AM   #3
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
most commercial distributors offer this product only in case quantity (24).
you can find the '721 product here in white, grey, and black, in quantity 1, or more. - https://store.airstream.com/product_...roducts_id=316
stick with the 721 rather than the 221. the 721 will last longer.
here's some links you might find useful.
http://www.wbcci.org/documents/Schus...ber%202007.pdf
http://www.wbcci.org/documents/Schus...Nov%202005.pdf
http://service.airstream.com/files/l...8f65c7c167.pdf
Airstream, Inc :: How To and Diagrams
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Sikaflex 1a sealant Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-22-2015 02:24 PM
Sikaflex at Home Depot? Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 04-14-2010 08:36 AM
SikaFlex 221 buy locally? rogerdodger Leaks - Weatherstrips, Gaskets, Caulks & Sealants 17 10-18-2008 05:37 PM
Storing Vulkem or Sikaflex cameront120 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-30-2007 05:24 PM
Sikaflex, Vulkem, and Parbond Questions JohnG Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 07-27-2004 08:06 PM
