Old 10-15-2008, 07:34 PM   #1
rogerdodger's Avatar
Fresno/Clovis , California
SikaFlex 221 buy locally?
Where can I get SikaFlex 221?? Lowes or H.D. Ace Hdwre??
Roger
rogerdodger is offline   Reply With Quote
Old 10-15-2008, 08:49 PM   #2
Images: 59
The only places I've ever seen it is a large full service RV dealership.
Old 10-15-2008, 08:50 PM   #3
1971 25' Caravanner
scappoose , Oregon
Try a West Marine store, or any good marine hardware store, or chandelry.
rangebowdrie is offline   Reply With Quote
Old 10-15-2008, 08:51 PM   #4
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
For information, what is SikaFlex 221 used for? Thanks for your answer.
willyd is offline   Reply With Quote
Old 10-15-2008, 09:02 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
SikaFlex 221 is a polyurethane formulation that Airstream uses as the primary sealant on the newer Airstreams. It is used liberally when joining segments, bedding windows, and for just about any large sealing requirements.
Smaller seams are sealed with Acryl-R, which is a solvent based product that never really fully cures.
I can't comment on it's availability, as I get mine from my major RV parts suppliers, but I know that it is available on the web. Just Google it and a bunch of outlets will pop up.
lewster is online now   Reply With Quote
Old 10-15-2008, 09:46 PM   #6
I was asking this question because I don't want to order a tube for $10 on the internet and pay $10 shipping. I will call around tomorrow. I want to use it to install 2 fantastic fans.
Roger
Old 10-15-2008, 09:49 PM   #7
cameront120's Avatar
1972 25' Tradewind
You won't find it at such stores. The most reliable source, other than on line or RV supply stores, are suppliers to the glazing industry. Check your yellow pages for glazing supplies. Marine supply stores also carry some types if Sika sealants, but not always 221.
North Vancouver, BC
Old 10-15-2008, 10:02 PM   #8
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
You should be able to order it at the Airstream Online Store.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 10-15-2008, 10:14 PM   #9
lewster's Avatar
Roger,
I don't use SikaFlex 221 to install roof vents or fans. The 'preferred' method in the RV industry is to bed the under side of the fan housing in 1 or 2 layers of butyl tape, press the fan housing to the roof and then attach it with stainless steel sheet metal screws all around. Then cover the screws and the fan/roof seam with a liberal application of Dicor self-levelling sealant.
I have installed over 50 roof fans and skylites with this method, and have never had a leak. It also allows you to remove the fan if required with not a lot of effort, where the SikaFlex will be extremely difficult to remove. I prefer it for more 'vertical' rather than 'horizontal' sealing issues.
Dicor and butyl tape can be had at any well stocked RV supply shop.
Old 10-17-2008, 06:59 AM   #10
Lewster, Thank you for the dicor and butyl tape suggestion. Do you think it is available at Campingworld?
Roger
Roger
Old 10-18-2008, 08:46 AM   #11
lewster's Avatar
Roger
Should be!
Old 10-18-2008, 01:39 PM   #12
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I have purchased Sikaflex at marine supply stores. I have used it for sealing areas as well as attaching door glass to window regulators on cars where there is no upper door frame like 60s pony cars (Cameros, Firebirds, Javelins etc).
Really good stuff.
Old 10-18-2008, 01:53 PM   #13
Originally Posted by lewster View Post
Should be!
Thanks, Lewster, Campingworld came thru. Now the fun begins, getting old vent out. Do these old vents have value to anyone??
Roger
Old 10-18-2008, 02:00 PM   #14
By the way Lewster, I notice you hang out in Hood River, Oregon. Is that where the Full Sail Ale is made? Mmmmm, reminds me, I need to make a beer run before I tackle the vent removal. I need some "bottled bravery" to go up on the roof.Hehe
Roger
Sikaflex 1a sealant Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-22-2015 02:24 PM
Sikaflex at Home Depot? Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 04-14-2010 08:36 AM
Storing Vulkem or Sikaflex cameront120 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 08-30-2007 05:24 PM
Can I get "D" gasket locally? pinkflamingoes Windows & Screens 5 04-18-2007 06:30 PM
Sikaflex, Vulkem, and Parbond Questions JohnG Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 07-27-2004 08:06 PM
