Old 10-06-2010, 10:01 AM   #1
Judy Barde's Avatar
1960 24' Tradewind
pittsburg , Kansas
Shower pan leak
I totally redid my 1960 tradewind. Had a shower pan fabricated. I ran over a tire treed in the road and it hit the plastic pipes and cracked the holding tank so had to rip out everything for the second time. Now that I have sealed the underbelly I noticed a small drip coming from under the belly pan. I am pretty sure it is the shower pan and taking it out is not an option. Would appreciate any suggestions. I was thinking if I could put a neat bead of something around the bottom inside of the shower pan that would maybe work??? I have used trempro 635 when I took out and replaced the upper fan vent, but it is very hard to work with and this is a very tight small seam. I also sealed all the seams on the outside of the shower pan with trempro but must have missed some. I now realize all the things I should and should not have done but now need to know how to solve the problem and have it still look nice. Here are some photos of the shower pan before and now. Thanks Judy
ID:	112536   Click image for larger version
S. Silver
Judy Barde is offline   Reply With Quote
Custom Shower Pan Tom Bray Sinks, Showers & Toilets 20 04-30-2017 09:29 PM
Can't get the shower pan out RV H-D Lady All Argosy Trailers 28 08-27-2014 10:53 PM
Removing shower pan guy99 Classic Motorhomes 5 09-30-2011 09:10 PM
Anyone curious about what's under the shower pan? SafeHarbor 1978- 1979 Excella 500 7 12-13-2010 03:22 PM
Mystery Rainwater Leak in Shower Pan Alsupp Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-25-2010 04:36 PM
