Old 02-10-2009, 01:44 PM   #1
Sewer vent pipe cover gaskets
We just replaced this sewer vent pipe cover gasket, yesterday.
It was removed from a 2005 30 foot Safari.
It''s only 3 1/2 years old.
Normally they last 5 years, but this one says otherwise.
We suggest that you add this to the top of your "PM to do list."
Old 02-10-2009, 02:13 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thanks Andy been there done that, at 2yrs.
Name:	SOLAR PANELS; ROOF LEAK 011.jpg
ID:	75290   Click image for larger version
Name:	SOLAR PANELS; ROOF LEAK 023.jpg
Name:	SOLAR PANELS; ROOF LEAK 020.jpg
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 02-10-2009, 02:46 PM   #3
gasket
2 years.
We wonder how many are leaking, without the owners knowledge?
Maybe everyone should have them checked and/or replaced before the warranty runs out.
Old 02-10-2009, 03:10 PM   #4
Kevin245's Avatar
Originally Posted by Inland RV Center, In View Post
2 years.
Probably more than we are aware of.
Does the failed gasket say "Made In China" on the back?
Thanks for keeping us aware of the often overlooked maintenance items Andy.
Eleanor Roosevelt
Old 02-10-2009, 03:38 PM   #5
Unfortunately, there are no markings of any kind.
I guess the warnings to everyone should change from the 5 years to 2 years.
The good part however, is that gasket is pretty cheap, and can be changed out in a few minutes, but vulkem sealer should also be applied around the circle, which should extend it's life.
Old 02-10-2009, 03:50 PM   #6
2 years.
I found it while on the roof for the Spring get ready. As you can see in the pictures, what got my goat was the fact that the factory only saw fit to install half the mount screws. I used an old inner tube and cut the gasket, drilled as necessary and replaced with stainless screws.
Thank goodness your on the Forums, cause there ain't no Andy on the East Coast!!!
RLC
RLC
"Tahawus"
Old 02-10-2009, 04:05 PM   #7
2002 30' Classic
Ocala , Florida
What's the best material to make the gasket from?
Bigdaddy_2 is offline   Reply With Quote
Old 02-10-2009, 04:17 PM   #8
The one above, post 2, I made from a new truck inner tube, a bit thicker and a lot more subtle. Used liberal amounts of polyurethane on both sides and around vent tube.
RLC
RLC
"Tahawus"
Old 02-10-2009, 04:30 PM   #9
1994 30' Excella
Mississauga , Ontario
You guys keep finding things for me to do. Mine is a 94 and I am sure they are original.
Al
Old 02-10-2009, 05:22 PM   #10
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
So what do you all use to remove the old goop and what new goop do you use to reseal the vent cap???
I have been putting this off on our '06, but I guess it is time I get up on the roof and take care of the vent cap and the cracking around the perimiter of the sky lights. My sky lights aren't leaking, but there is a crack line between each and every screw around the perimiter of every skt light.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 02-10-2009, 05:40 PM   #11
That's because of the material used along with excessive tightening of the screws.
There are hundreds of owners with the same problem.
Unfortuantely, very few are aware of "what's happening" on the roof.
The roof must be checked periodically, or else you may pay huge penalties, should the trailer not be used for a while.
Old 02-10-2009, 05:46 PM   #12
Carl,
Sounds like the same guy was on your roof too...
This worked for us..
Name:	SOLAR PANELS; ROOF LEAK 021.jpg
RLC
RLC
"Tahawus"
Old 02-10-2009, 07:05 PM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I recommend EPDM roofing material, the black stuff they use on commercial roofs. It has UV inhibitors in it and is designed to be exposed to the weather...some of those roofs even come with a 10 year warranty
Watch for a roofing in job in you area, ask the guys they will be glad to give you a few scraps, then use your vent cover piece as a pattern and cut it just a bit bigger.
Aaron
WBCCI #XXXX AIR #2495
Old 02-11-2009, 07:13 AM   #14
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
One of my many hobbies is building water features. I have pond liner with UV protection and have cut the gasket out of that material. You may be able to buy a scrap piece at one of the big box stores.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
Changing valve cover gaskets on 460 Nick Danger Mechanics Corner - Engines, Transmission & More... 12 09-08-2005 05:28 PM
make your own vent pipe gaskets 0557 Roof Vents, Skylights & Fans 13 09-13-2004 11:42 PM
Replace original vent pipe cover? rluhr Roof Vents, Skylights & Fans 18 08-30-2004 12:12 PM
New Vent Pipe Gaskets Joe Z Waste Systems, Tanks & Totes 0 06-27-2004 09:46 PM
