Old 04-01-2009, 07:54 PM   #41
"Cloudsplitter"
Originally Posted by wppii View Post
For RobertCross, note that standard installation calls for only 6 screws, the rest are extras.
FWIW...I would use as many you can, you can see how ours separated. The pdf says use 'em if 'ya wanna....I 'wanna.
Good Luck
Stream Safe
Old 04-05-2009, 09:58 PM   #42
wppii's Avatar
2004 28' International CCD
East Nicolaus , California
Images: 33
How the Lovin' Oven got fixed...
Finally, got it done.
Cleaned off the old sealant, trimmed a new sewer vent cap base to fit around the refrigerator vent, extended the vent pipe with a trimmed down ABS pipe connector and a short piece of pipe, applied Sik Flex 221 to the base, and installed it with the old screws supplemented with weatherseal washers.
No rubber gasket required!
Except for the jury-rigged extension of the pipe, this is how the vent cap should be installed.
ID:	77993   Click image for larger version
ID:	77995   Click image for larger version
The Lovin' Oven is an 04 28' International CCD.
It follows where the F150 Supercrew leads.
"The only time to say "No" is when they ask if you've had enough"
wppii is offline   Reply With Quote
Old 04-05-2009, 10:12 PM   #43
wppii's Avatar
Images: 33
Final pics....
For any who are interested, there are many more pictures.
Here is the final installation
ID:	77997   Click image for larger version
ID:	77999   Click image for larger version
Old 06-10-2009, 09:04 PM   #44
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Just brought the Safari home today, waxed it, flushed the plumbing, and went to check the roof. My vent oddly enough is not caulked. I has what appears to be a mortite type material. It did crack, but was easily smoothed out. Still, I looked at my roof vents and such and the caulking is not really doing all that well. I am thinking I have some roof work to do at some point.
Also on a side note, I went around the Safari today with Acryl-R and was astonished to find that a handful of places needed some help. More than I thought I'd see in a 5 year old unit.
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
Changing valve cover gaskets on 460 Nick Danger Mechanics Corner - Engines, Transmission & More... 12 09-08-2005 05:28 PM
make your own vent pipe gaskets 0557 Roof Vents, Skylights & Fans 13 09-13-2004 11:42 PM
Replace original vent pipe cover? rluhr Roof Vents, Skylights & Fans 18 08-30-2004 12:12 PM
New Vent Pipe Gaskets Joe Z Waste Systems, Tanks & Totes 0 06-27-2004 09:46 PM
