Old 02-11-2009, 07:29 AM   #15
soldiermedic's Avatar
Florissant , USA
While I was testing trailers for leaks in Texas last weekend, none of the owners knew about the sewer vent gaskets and that they went bad. I suggested to all of them to have them replaced.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-04-2009, 09:11 AM   #16
Utahgoldrup's Avatar
1991 25' Excella
Salt Lake City , Utah
This thread is perfect for what I am needing to do. I have two vents on top of my trailer, once next to the oblong looking vent for the refridgerator and one between that and the AC, they both look nearly identical and have the gaskets down inside that I want to replace.
I saw Carl ask what you used Bob to remove the existing sealer/goop with, is it the acrylclean in your picture? I need to remove this stuff first and can see the screws that need to be removed so I can get at the gaskets. My vent covers are made of a diecast metal but I am sure the process of removing and cleaning is the same?
Utahgoldrup is offline   Reply With Quote
Old 03-04-2009, 09:22 AM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Ok, I'm sold on this, but were can I get the gasket Andy is suggesting?
Old 03-04-2009, 09:49 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yep, The acrylclean is what I used. Used a plastic scraper to remove the old goop and cut the new gasket from a truck inner tube. Will be up there again this Spring re-sealing the sky-light and both FFans. Still got some goopy factory foot prints to clean up too.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-04-2009, 10:32 AM   #19
We have them.
http://www.inlandrv.com/catalog/imag...entpipecvr.jpg
Old 03-26-2009, 10:12 AM   #20
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Is it necessary to climb onto the roof to replace the sewer vent gasket or can it be done while reaching from a ladder ????? If you must climb onto the roof what precautions must be taken to avoid damage ???? Plan on doing this job soon and of course will probably find other locations that need to be re-sealed or repaired.
Thanks for any advise
Roger Kriz
kriz@rci.rutgers.edu
polarlyse is offline   Reply With Quote
Old 03-26-2009, 11:21 AM   #21
Roger Kriz
The sewer vent pipe covers can be reached from a ladder.
Old 03-26-2009, 04:00 PM   #22
1991 25' Excella
Thanks Bob! I have my vent seals ordered and once I have them, will use acrylclean and a plastic scraper like you mentioned to get the goop off. What is the process on putting the new seals on? Do you put any sealent down first or just put the gasket down, vent cover on top, screw it down and then put sealent around the vent pipe cover? I just want to make sure I put it all back the right way so I don't have to re-do that job.
Old 03-26-2009, 04:20 PM   #23
We supply fiberglass screening material with our sewer vent pipe cover gaskets, at no charge.
The screen is installed over the pipe, then the gasket is slipped over the screening and the pipe. Vulkem sealer is then used to fill the void between the center hole of the gasket and the black pipe, thru the screening for a positive seal.
Old 03-26-2009, 04:52 PM   #24
Thumbs up
Just the way I did it, other options may vary..
After some trial and error I found it easier to just run a good bead on bottom side of gasket, stick over the opening, another bead around center opening and outside edge and vent pipe.
The opening in the shadetree gasket I made fit very tight over the tube and was easy to seal.
Also on this style vent I plugged the access tube for the cap screw that holds the cover to the roof flange.
Tighten those new stainless screws your using carefully
On this style cover the factory saw fit to only install 6 of the 10 screws.
IMHO..might as well fill the empty holes.
Used a stainless screen from an old pasta strainer over the vent opening.
Name:	SOLAR PANELS; ROOF LEAK 023.jpg
ID:	77488   Click image for larger version
Name:	SOLAR PANELS; ROOF LEAK 022.jpg
Name:	SOLAR PANELS; ROOF LEAK 020.jpg
PFC
"Tahawus"
RLC
John Prine
Old 03-27-2009, 08:48 PM   #25
Ottawa , ON
There's one for each tank right? Black, gray and the fresh water too? (Can you tell I don't live close to my trailer?)
Courage is being scared to death, but saddling up anyway.
Old 03-27-2009, 09:12 PM   #26
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If your 74 is like my 75 Trade Wind, you will have two vents. The Black and Grey tanks share one vent and there is another vent by the kitchen sink.
Richard
Old 03-28-2009, 10:45 AM   #27
You could have 2 or 3, sewer vent pipe covers.
The water tank venting, is very different than the sewer vents.
The black and gray tanks are the only gasket concern.
Old 03-31-2009, 01:14 PM   #28
wppii's Avatar
2004 28' International CCD
East Nicolaus , California
Images: 33
May be a dumb question....
Are the vent covers installed incorrectly in the first place?
The top of my plumbing vent cover says to vent the pipe 2" to 2-1/2" above the roof. If the pipe is that high, it will have a friction fit with the lower portion of the vent cover, just like a roof jack on a house, i.e. the pipe will stick up through the center hole tightly enough that a thin bead of caulk will seal the area. That would eliminate the need for a rubber gasket to seal against the outside of the pipe lower down. It would also eliminate the need for any drain holes to get water off the top of the gasket, like the old style vents had. Then the only other place to seal is around the outer perimeter of the vent cover base.
Of course, my vent pipe only sticks up 1-1/2", so, unless I extend my vent pipe, I have to have the inner gasket. But it just doesn't seem to be properly installed.
Am I in left field here?
ID:	77707   Click image for larger version
ID:	77709   Click image for larger version
The Lovin' Oven is an 04 28' International CCD.
It follows where the F150 Supercrew leads.
"The only time to say "No" is when they ask if you've had enough"
wppii is offline   Reply With Quote
Staining Sewer vent from sewer gas TheProfessor Cleaning, Stripping & Polishing 6 02-16-2008 01:42 PM
Changing valve cover gaskets on 460 Nick Danger Mechanics Corner - Engines, Transmission & More... 12 09-08-2005 05:28 PM
make your own vent pipe gaskets 0557 Roof Vents, Skylights & Fans 13 09-13-2004 11:42 PM
Replace original vent pipe cover? rluhr Roof Vents, Skylights & Fans 18 08-30-2004 12:12 PM
New Vent Pipe Gaskets Joe Z Waste Systems, Tanks & Totes 0 06-27-2004 09:46 PM
