Old 03-20-2011, 10:03 PM   #1
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
sewer pipe/belly pan caulk
I would like to know about the caulking found around the sewer pipe and on the seams of the belly pan. It seems like it was originally white and still pliable.
I need to seal the area around the sewer pipe.
Any ideas on where to find this stuff?
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 03-20-2011, 10:25 PM   #2
Use Vulkem sealer.
A few Airstream dealers sell it.
Old 03-21-2011, 04:29 AM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
That original stuff looks like butyl tape - sold at most RV dealers. It was used on ours around any of the pipe openings, etc. on the belly.....
Old 03-21-2011, 05:57 AM   #4
crispyboy's Avatar
1994 30' Excella
Thanks - I do have some Vulkem I can try out. It just seems like this stuff was tougher than your typical butyl tape - looks like it was applied with a caulking gun.
WBCCI # 3072
Old 03-21-2011, 09:14 AM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You can still buy butyl caulk - it's generally used for flashing. Airstream may have actually used it in that form. The vulkem Andy recommends should work. I never thought of using it personally - just went back with what was on there.
which aluminum sheet for belly pan???? clipperguy Belly Pans & Banana Wraps 2 04-26-2011 06:21 PM
Screen on Sewer Vent 73 Tradewind constructor Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-20-2011 08:35 PM
Need Help with a Spare Wheel and Sewer Hose for Int'l 19'? jambie 2005 and newer - Bambi all models 4 03-07-2011 08:50 PM
Dent in water tank galvanized pan safariuser Belly Pans & Banana Wraps 1 02-26-2011 06:37 PM
A/C pan replacement Airhouse Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-28-2011 08:16 PM
