Old 11-12-2014, 11:47 AM   #43
1964 24' Tradewind
Lawrence , Kansas
I just did my 64 Tradewind. Both the 635 and the Acryl went futher than I expected. 1 & 3/4 tubes of 635 and 2/3rds of a can of Acryl. Use blue masking tape but I suggest not tape too far ahead. This is especially true of the Acryl. It gets tacky quickly and will get stringy when you pull the tape off. It cleans off with lacquer tinner but why add a step. I did every seem except some of the sides of windows where the seem looked to be in good shape Going to do the rivets with Capt T in the spring.
ttbikes is offline   Reply With Quote
Old 11-12-2014, 12:36 PM   #44
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
For my 69 Safari I have completely removed every last bit of old sealant from the cracks and crevices... and really sealed it up good using a medicine syringe (the kind you give kids medicine with, not the needle kind) to pump it deep into the spaces. I sealed every window and flashing, all access panels, removed cleaned and replaced all the roof plumbing vents, stove hood and fridge hood covers. Repaired and replaced a broken wing window with Lexan and all that with not even two tubes of grey Sitkaflex. It cures rubbery so its not getting covered in dirt debris like some of the other sealants that remain tacky forever. For any overlap seams that let in moisture and around the door I used the aluminum tint gutterseal I purchased from vintage trailer supply. Can barely tell I have used any, the tube doesn't even look squished yet. Then I used captain tolleys on all the rivets and the seals around the windows that have shrunk with time and were letting water in, At first I used a 3mm hypodermic syringe to apply the captain tolley's to each rivet but it started clogging the needle so I gave up and applied right from the bottle. Clean up any excess with a damp cloth right away or you will have some elbow grease to remove the runs.
Just finished the front half of the trailer yesterday with the tolleys and hosed her all down top to bottom for 20 straight minutes this morning and the front is completely bone dry inside. Take your time do it right and you will be very happy in the end. Of course how tidy you are with your application and how thick you make your seams will make the difference with how much you use in the end.
So for me 1.5 tubes sitkaflex, 1 tube Aluminum tinted Gutterseal and by the time I finish every last rivet and the rear window seal I expect will need to purchase two small bottles of the captain tolleys. I purchased the Tolley's from West Marine here in Canada very recently
thesignlady is offline   Reply With Quote
Old 11-12-2014, 07:04 PM   #45
I just used the Capt Tolleys this past weekend and I found that if a little too much seeped out around a rivet I was able to quickly dip my finger in the rivet and touch other near by rivets... I could sometimes seal about 5 rivets just from the application of the one rivet. That stuff goes amazingly far, I think I might only use one bottle for my entire trailer.
Trixella is offline   Reply With Quote
Old 03-03-2015, 01:58 PM   #46
mskinner23's Avatar
1994 30' Excella
Alamosa , Colorado
Eternabond tape
Has anyone ever used Eternabond Aluminum-backed tape to seal roof seams?
mskinner23 is offline   Reply With Quote
Seam sealing from the inside? ironheadxlch General Interior Topics 19 09-04-2015 09:08 AM
interior seam sealing GR8DANE Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-09-2013 12:58 PM
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 01:53 AM
Need Advice on Seam sealing material nm1oqrz Ribs, Skins & Rivets 4 02-16-2011 12:44 PM
Seam sealing - again Fyrzowt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-08-2006 01:01 PM
