Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 01-13-2003, 09:36 AM   #1
mgordon
mgordon's Avatar
Profile:  1974 31' Sovereign
Magnolia , Texas
Question Sealing Windows & Caulking outside
We have just bought a 1974 International (29 ft). It is in overall good condition, but with the rain that we had this past weekend we found 3 leaks. 1 around the left front window, 1 above the left side window (not sure where it is coming in / dripped down the wall) and one by the kitchen sink window.
What caulk is recommended to use on the A/S and should we do all of the seams?
Also looking for someone in the Houston or surrounding area that we could maybe get a little mentoring from. This is our first camper and our family is very excited to have it, but we have many questions. The forums are great and I have found many helpful things already on this site.
Thanks.
Michele Gordon
mgordon is offline   Reply With Quote
Old 01-13-2003, 10:20 AM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
While I don't live in the Houston area, there is a good thread on this subject that can give you some info on caulking until someone from your area chimes in. Try Tell me more about caulking... for starters. There are many additional threads discussing this subject...try doing a search using "caulking exterior" as the keywords.
As far as a mentor...you'll find lots of knowledgeable folks right here on the forum! Another idea is to look into the local WBCCI unit in your area www.wbcci.org. Houston is in Region #9 and there are several groups in Texas, there's sure to be one to meet your needs.
Good luck as you begin your restoration!
Shari
Old 01-13-2003, 11:33 AM   #3
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
MG,
Welcome to the forum! Leaks on a A/S can be tricky to find. I would start on top of the roof first. If water gets in up on the top, around say around the antennae, plumbing vents, roof vents or a/c, it will travel all around the inside skin and run down anywhere. I have seen my Overlander leak at the rear by the bathroom wall with water that came all the way from the front roof antennae mounting. If you have vista windows that would be another place to look, almost guaranteed leakers if they haven't been attended to. After the roof I would caulk the tops of the windows, right where the drip rail mounts. I have also heard the awning rail can be a problem. You should be using either parbond for the tight seams and vulkem for the larger seams. There is a lot of info on the subject of caulking so just do a few searches. Good luck!
Chas
Chas is offline   Reply With Quote
Old 01-13-2003, 12:18 PM   #4
mgordon
mgordon's Avatar
Magnolia , Texas
Smile Sealing Windows & Caulking Outside
Thanks for the help and advice.
I have been doing some searches so I have learned some on what to use to seal the seams and windows. I will check our local dealers for the parabond and Vulkem.
Michele Gordon
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Open your frameless windows wide? TomW Windows & Screens 17 08-23-2004 08:14 PM
Vista windows "filmy" pilgrim_still Windows & Screens 35 08-04-2004 11:48 PM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 06:14 AM
Leaky Windows & Skin Replacement PizzaChop Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-08-2004 11:13 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
