Old 01-12-2014, 01:26 PM   #1
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Sealing Wall Penetrations
Well I am excited to see our new Riveted version of the Stainless Steel water heater door on Pete (thanks OoDM). The dull finish door had to go. Of course now I need to get some of that shiny spray paint and work on the dull gray electrical outlet cover.
Reason for the post is I am wondering if the $2 foam gaskets behind the W/H, furnace, stove vent, electrical outlet, etc. on all the wall penetrations on our coach is good enough for leak proofing these large openings. Perhaps a bead of caulk along the top of the foam gasket? Pull all the screws out and seal them before re-installing? Rubber diverter caps? There has got to be something better than leaving these alone and risking having water run down inside the outer skin and say hello to the plywood floor!
What have some of you done to ensure that these not very effective gaskets keep water from entering our beloved Airstreams?
Name:	SS WH Door.jpg
ShinyPete is online now   Reply With Quote
Old 01-12-2014, 03:16 PM   #2
lewster's Avatar
Naples, FL , Hood River, OR
SikaFlex 211 in grey matches the outside aluminum of your Airstream perfectly. It's the same stuff (moisture cure polyurethane) that the factory uses.b
Old 01-13-2014, 05:45 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Your "dull gray electrical cover" can also be replaced with SS! Mine came from Menards.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
