I noticed on a video with Vinnie's Northbay Airstream he was sealing the rub rail very carefully.
I am assuming there is a horizontal seal there? I am assuming this is important to seal/reseal when the time comes? There is a rub rail mid-height and one down low.
The lower rub rail covers banana wrap and side panels. Very def. seal by running sealer along top of rail, middle I don't no if cover a seam or not but I always caulk same as bottom, as under vinyl strip are pop rivets that hold rails on.
The bottom rub rail is where the shell/floor/bellypan meet. The bellypan overlaps the shell which will allow water to run right to the floor. You need to caulk this area.
