Old 07-15-2010, 03:07 AM   #1
1973 29' Ambassador
Anchorage , Alaska
Sealing the inside seams?
I am finishing up patching all of the holes in my skin and about to leak test everything. My question is there something I can spray on the inside of the skin on the seams? I was thinking of using automotive undercoating. there are a few brands that weather extremely well and would be thick enough not to run down the walls. I am really worried about leaks after I seal up the walls and I have bucked several patches and used vulkum but my OCD is getting to me.
thanks
mike
akmntman is offline   Reply With Quote
Old 07-15-2010, 07:38 AM   #2
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
do you mean on the inside of the EXTERIOR skin or the inside of the inside skin? im assuming inside of the exterior skin?
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 07-15-2010, 08:17 AM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
I used Seamermate amerimax.com (Home Dept.) Comes in a tube for a caulk gun.$4.99This is a non silicone seam sealer for aluminum gutters.I will probably seal the outside too after talking with Bob Thompson (check his thread on this)He applied this product in 2004 and very pleased with the results.It dries silver gray.
bwaysteve is offline   Reply With Quote
Old 07-15-2010, 10:42 AM   #4
1973 29' Ambassador
Anchorage , Alaska
Yes the inside of the exterior skin, I will look for it at home depot. I was thinking of a spray but that sounds good. I noticed that some of the older as have a black substance on the inside seams and I think a saw something about it being tar?
Old 07-15-2010, 10:49 AM   #5
_
to OVER seal the inner side of the outer skin, patches, holes, fixtures and so on....
use sikaflex 221 and apply LIBERALLY.
or apply tempro/vulkem if u r into that old sealant, period correct stuff.
this is how they do it in j/c on the new units and major skin repairs on older units...
cheers
2air'
Old 07-15-2010, 11:06 AM   #6
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Uwe's comment
Uwe Salwender told me at the Resto Rally to take asoft wire wheel on a drill and clean the seams so the new stuff will stick.
Resealing all seams? MonaxLisa Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-10-2010 11:11 AM
Ice in exterior seams putback Ribs, Skins & Rivets 8 07-06-2008 12:01 PM
sealing seams in the wheel wells.. safari25-05 Wheel Wells 6 01-16-2007 03:38 PM
Sealing Olympic Rivets From The Inside Dan Clayton Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-13-2006 09:02 PM
sealing leaks from inside lwebb Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 05-20-2006 07:36 PM
