Old 02-07-2016, 02:02 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
Cumming , Georgia
Sealing outside rail
Had a 2" gap in top of rail open up. Water getting in and freezing. I put a bead of ACRYL-R to seal but smeared some on the aluminum panel. HOW DO YOU CLEAN THIS STUFF OFF? Will Goo-Off work or some other application? Also, how do you clean the Acryl-R pump? Can you just leave it in container with the pin inserted in applicator?
DeltaRon is offline   Reply With Quote
Old 04-03-2016, 09:18 AM   #2
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
Working with Acryl-R
I will take the easy question: for the Acryl-R applicator, I just leave it in the can. A year after my last use, I can pick it up and use it again. At some point it may freeze up, and then I will get another applicator.
The hard question - how to remove Acryl-R. I have not found a way. I have replaced side marker lights and sealed with Acryl-R, and gotten some smudges where I don't want them. I wiped with a rag, and left what remained. I did not try goo-gone or anything, as I didn't want to see if it affected the clear coat.
Good luck!
RAH is offline   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
Rub rail sealing sarasafari Exterior Restoration Forum 3 03-14-2013 06:29 AM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 12:18 PM
