Old 07-07-2010, 08:23 PM   #1
2010 27' FB International
Birmingham , Michigan
Sealing Materials
Can anyone tell me what kind of sealant to use on the various exterior parts of the AS. Around the windows it looks like an aluminum colored material. What is it? Also, what kind of sealant should be used on plastic items (vents, stack, AC, etc.).
Thanks.
Aquabud is offline   Reply With Quote
Old 07-14-2010, 08:21 PM   #2
jmpratt's Avatar
1969 29' Ambassador
Liberty Township , Ohio
I use Vulcum 116. Inland RV has it. I've been told that's what Airstream uses. I used it to install some fantastic fans and it works great.
jmpratt is offline   Reply With Quote
Old 07-14-2010, 08:49 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Thanks.
The Airstream factory uses SikaFlex 221 one part polyurethane sealant on all large seams on the trailer and as a bonding agent on the panel overlap areas that you don't see, and Acryl-R for the smaller seams where wicking into the seam is required.
Many OEMs of large, luxury motor homes also use SikaFlex 221.
Roof sealing can use the same product or their self-leveling Sika-Flex 715.
Great product that I use constantly.
Old 07-14-2010, 09:05 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Trempro 636 is the new name for Vulkem. Your local Fastenal store will have it or can get it in a day or so. I use it most sealing jobs. You can put some in a large syringe and it will give you a small bead for places where you need a very thin bead.
Interior walls - looking 4 a materials supplier gonorthwest Upholstery, Blinds, Walls & Interior Finishes 1 10-31-2009 10:07 AM
grade and specs for restoration materials batt Interior Restoration Forum 7 09-04-2009 07:48 AM
Replacement Materials Serena Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 0 05-03-2008 09:27 AM
Frame repair materials Skytrailer Repairing/Replacing Floor &/or Frame 2 08-23-2007 07:23 PM
Source of Window Materials noiva General Motorhome Topics 6 02-06-2006 12:12 PM
