Old 01-29-2012, 05:28 AM   #1
2004 16' International CCD
Orem , Utah
Sealing lights on ext 2004 Bambi Int
Ok just got this trailer and appears to leak in rear bunk area. I have a drip almost straight accross matress near tear drop. I am thinking fellow pressure washed with unit maybe even acid wash. Could the sealants used be damaged and need doing over. What products should I get. For boats I would get 3m 4200 but would be tough getting off trailer for later service. Should I also do tail lights the caulking is cracked. Do I need to pull these off or touch up
starcraft is offline   Reply With Quote
Old 01-29-2012, 06:34 AM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
starcraft,
Here are some of the products I have used for sealing the AS....
Acryl-r for any panel or close fitting seams.
Sika uv & Parbond for the larger seam gaps.
And mineral spirits for clean-up
forgot some....
Name:	small_Acryl-R 16oz Can.jpg
ID:	149766   Click image for larger version
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-29-2012, 07:41 AM   #3
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Morning Bob, does that sealer that you use on lg panel dry clear?
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 01-29-2012, 08:12 AM   #4
Thumbs up
Jim,
The acryl-r comes in clear and aluminum.
The only color I've found for the 721 uv is off-wht, not sure if any other color is available.
The parbond I used was also off-white. Alum also available.
I used the Loc-tite ppl on the black tank vent and rear bumper moulding, black only.
PFC
RLC
Old 02-04-2012, 08:16 PM   #5
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
lights = r&r , bead of vulkem (grey) rivet back on and clean off excess with rag and mineral spirits. make sure light is right side up.
seam leaks = small bead of grey vulkem along seam, work into seam 10-20"s at a time,wipe off excess with rag and mineral spirits (latex gloves will disolve in ms but are cheap) wipe towards seam as you clean and new seal will be invisable. takes patience and vulkem is messy to work with but very effective.
crestonrv is offline   Reply With Quote
'61 Bambi interior lights ragin-cajun General Interior Topics 3 02-04-2012 09:28 PM
Scam Alert: 2004 Bambi PatrickW Off Topic Forum 1 11-21-2011 06:09 PM
Rosco :: 2004 International CCD Bambi Grizzly6 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Interior Light 2004 Bambi CowtwnSilver Lights - Interior & Exterior 3 05-11-2011 07:49 PM
