Old 07-12-2015, 07:05 PM   #1
Savannah , Georgia
Sealing From the inside
I have searched and cannot find any info on this subject. All of my interior skins have been removed. I would like to seal all of the seams as an added precaution. What would be my best option? Maybe a think coat of tremco or even silicone?
Glt12 is offline   Reply With Quote
Old 07-12-2015, 07:57 PM   #2
1981 31' Excella II
New Market , Alabama
Well don't use Silicone. Trepro would be ok. The hardest thing is getting all the olde sealant off to put new stuff on.
Perry
Old 07-12-2015, 09:19 PM   #3
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Seam sealing inside edges of exterior panels
After you clean-up inside exterior panel seams you should first use Captain Tolleys Creeping Crack Cure. It will wick into the smallest spaces in between the panels. Then you can add Trempro or Acryl-R to the seams and create a sealant dam to add to your leak proofing of the inside seams at the panel overlaps. In addition you should also use this same two layer application to the outside seam edges to really have the best protection against water intrusion! This process almost mimics the seal that was used at the factory between panels on overlapped seams and goes the extra step to add sealant at both inside and exterior seam locations. The more sealing you can get the better lasting leak prevention you will achieve. Don't forget to check and seal all rivets using the same technique. Then seal all rails, lights, id plates, etc. to help keep moisture from getting inside! Hope you have a real good experience doing this as the benefit will last much longer than the time it takes to do the work. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-14-2015, 06:23 AM   #4
1981 31' Excella II
Before putting the skins back on, sit in the trailer while it is raining and look for leaks. You will find some in odd places.
Perry
Old 07-28-2015, 12:46 PM   #5
1977 31' Excella 500
Bonnyville , Alberta
[/url][/IMG]
Zenstream1 is offline   Reply With Quote
Old 03-28-2017, 01:45 PM   #6
1960 22' Flying Cloud
Saltspring isl. , British Columbia
Hi. I'm about to seal from the inside. But all the seems are coated in some sort of tar, from the factory I think. I'm guessing this all needs to come off first. Has anyone had experience with this before? What do you think?
Forestja is offline   Reply With Quote
Old 03-28-2017, 02:46 PM   #7
Here's a photo
Seam sealing from the inside? ironheadxlch General Interior Topics 19 09-04-2015 08:08 AM
Sealing exterior skins, inside? cuyeda Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 05-15-2014 06:31 PM
Sealing the inside seams? akmntman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-15-2010 11:06 AM
Sealing Olympic Rivets From The Inside Dan Clayton Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 11-13-2006 09:02 PM
sealing leaks from inside lwebb Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 05-20-2006 07:36 PM
