Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 11-21-2006, 09:04 AM   #15
godelad
Profile:  1965 26' Overlander
montauk , New York
Laps seam sealant
The pros at P&S trailer in Helena Ohio use the same product that the Airstream factory uses. It's a black tape material that might require you to separate the panels far enough to get it into place. I plan to use it (if I can get them to sell me some) for a lower panel replacement to fix a long scratch.I stopped there to get some advice on the fix and he showed me some. He said it was a relatively new product and swears by it. I have been searching for a tool to make a long straight cut in the new alluminum panel without distorting the edge. Any advice?
godelad is offline   Reply With Quote
Old 11-21-2006, 05:50 PM   #16
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
To cut aluminum I use a big hyd. shear at work, at home I use a angle (90 degree) die grinder with a .032 abrasive cutting disc fallowed by a vixon file followed by a 3M blue surface conditioning disc to deburr. I,ll take pics if you want.
Belly skin alternatives? Sneakinup Belly Pans & Banana Wraps 27 04-23-2004 07:33 PM
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 1 06-01-2002 09:08 PM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 03:54 PM
refrigerator panels eraffety Airstream Motorhome Forums 2 04-01-2002 12:20 AM
Solar Panels VONZIPPER Generators & Solar Power 7 03-18-2002 08:47 AM
