Old 10-03-2011, 08:55 AM   #1
2007 27' Safari FB SE
Wheat Ridge , Colorado
Sealing black and grey tank vents
Greetings,
While washing the A/S I noticed that the "putty/sealant/caulk" around the grey and black tank vents on the roof were cracking. What/how should i go about repairing this? What kind of sealer should I use? I assume I will need to scrape the old material off. What should I use to do that? Is there a technique for doing so that minimizes damage to the roof? Are there bolts or somehting hidden under the "putty/sealant/caulk".
I bet there is already a thread about this but I am not computer savvy enough to find it.
Please and thank you,
Pat
The Driver is offline   Reply With Quote
Old 10-03-2011, 10:05 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Pat - one of these may help you:
http://www.airforums.com/forums/f456...ent-35651.html
http://www.airforums.com/forums/f163...nts-24437.html
Anybody add a grey tank to late model bambi? sigv Waste Systems, Tanks & Totes 3 05-27-2012 09:54 AM
New '67 Safari black water tank? losfew Waste Systems, Tanks & Totes 1 09-06-2011 06:19 PM
Grey water tank for 1973 AS Tradewind 25' mblaksley 1970-79 Tradewind 4 06-07-2011 12:43 PM
How much black / grey is enough? Darkspeed Waste Systems, Tanks & Totes 5 05-26-2011 07:39 AM
Alternative to adding a grey tank, 60s rig eubank Waste Systems, Tanks & Totes 12 04-06-2011 02:54 PM
