Old 08-16-2014, 03:41 PM   #1
falcon-N-Air's Avatar
1995 34' Excella
Dalton , Georgia
Sealing around Exterior Lights
Hello all,
Needing info for the best Sealant to use on the Exterior Lights. Many Thanks!
Eric & Michelle Shuler
1995 34' Excella
2003 Chevrolet Silverado Z71
WBCCI # 7096
falcon-N-Air is offline   Reply With Quote
Old 08-16-2014, 04:54 PM   #2
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
this may be interesting!
I am thinking of making Rubber Gaskets the same footprints of the light fixture. I am then thinking of using sealant at the screws so that it can be removed in the future.
I am considering using Silkaflex because of the elasticity making it easier to remove.
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 08-16-2014, 07:00 PM   #3
1995 34' Excella
Dalton , Georgia
Thanks for the info steve,much appreciated.
1995 34' Excella
WBCCI # 7096
Old 08-17-2014, 07:08 AM   #4
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
Sikiflex 221. Gray color with some elasticity. Google it for details.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 08-17-2014, 07:50 AM   #5
1995 34' Excella
Dalton , Georgia
Thanks AC,
I have some Vulkem and Parbond, would this be sufficient since I already have some on hand? many Thanks,
1995 34' Excella
WBCCI # 7096
Old 08-17-2014, 12:51 PM   #6
dznf0g's Avatar
Oswego , Illinois
I have always taped off and used a thin application of par bond. Have not had to re-apply after 4years yet, and it still looks pretty much like it did right after application.
-Rich-
Old 08-17-2014, 02:37 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
You can tape it off & use Vulkem too. I've used that for many years. So, the choice between the two is up to you :-)
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-17-2014, 04:01 PM   #8
1995 34' Excella
Dalton , Georgia
Thanks Rich and Becky, that is what I needed to know…I have some of both on hand.
1995 34' Excella
WBCCI # 7096
Old 07-13-2015, 02:27 PM   #9
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
When you tape off your clearance lights to reseal what is the gap you try to tape off.
Do you remove the clearance light housing. I don't know what it looks like with the lens off but I'm guess there is hole for the wires and the holes for the mounting screws. Should those be sealed then the housing reinstalled and then a thin bead around the base. Would Acryl-R be a good candidate for the base with Termpro 635 or Parbond for the wire and mounting holes?
Kelvin
Old 07-13-2015, 08:08 PM   #10
1979 23' Safari
Wayland , New York
Would Acryl-R be a good candidate for the base with Termpro 635 or Parbond for the wire and mounting hole?
I'd probably go with parbond for the base and trempro 635 for the wires and hole. Acrylic r is better for the seams, and I've never been happy with the 635 performance in sunlight, seems to chalk up and dry out quickly.
When I tape off I usually end up around 1/32" ish, don't measure it, just try to keep it pretty close.
Most light bases have small holes on the base to allow drainage, make sure it's on bottom and don't cover it with sealant.
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Sealing around atwood water heater Hueytownalss Water Heaters, Filters & Pumps 1 06-02-2011 10:07 AM
Sealing around the glass bigjohn Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-16-2010 04:33 PM
sealing holes and around pipes kamo Plumbing - Systems & Fixtures 1 11-17-2006 10:23 AM
Sealing around the A/C Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 11-05-2002 04:29 PM
