Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 11-05-2002, 03:45 PM   #1
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Sealing around the A/C
I've been prepping for re-caulking up on the roof...vents and the antenna are the main focus, but I thought I'd check out the a/c while I was up there. It seems like the metal roof just "ends" at the ac; no flange or anything around there. there is a spongy gasket that makes a tight seal around the opening in the roof, but I'm wondering if this is "leak proof"? there are a couple of small remnants of caulking around, but it doesn't really look like caulk would stick to this material. its not like a metal-to-metal joint....what should I do with this? just leave it? caulk it?
Old 11-05-2002, 04:29 PM   #2
Airstreamer67
Airstreamer67's Avatar
Profile:
I installed a new Coleman 13,500 BTU unit on my Overlander. It's been a couple of years now, but I don't remember using anything on the gasket that came with the unit. I haven't experienced any leaks so far.
Airstreamer67 is offline   Reply With Quote
Is A/C original? whistler Furnaces, Heaters, Fireplaces & Air Conditioning 2 01-19-2004 04:32 AM
34' Excella 1000 needs cooler A/C cjholloway Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-17-2003 06:50 PM
understanding A/C options Lexxy Furnaces, Heaters, Fireplaces & Air Conditioning 24 08-02-2003 05:29 PM
A/C blowing the breaker Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 13 07-08-2003 10:52 AM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
