Old 08-19-2016, 11:51 AM   #1
Native143's Avatar
2013 20' Flying Cloud
Dunedin , Florida
Sealing and caulking - Help please.
I went to check my roof for hail damage yesterday and noticed that the caulk all around the roof seam is chalky and if I touch it, it just disintegrates in my fingers Yikes!! So I guess I need to remove and replace even though my AS is only two 1/2 years old and the dealer supposedly recaulked it when I bought it in Dec. 2014.
#1. Is this usual to deteriorate so quickly?
#2. How do I easily remove the old?
#3. What is best for the new?
I live in hot Florida. Lots of rain and exposure to the elements. I see lots of different opinions on what to use but I need easy and efficient.
Thanks a bunch. It's been pouring rain daily. No leaks seen yet.
"I'd rather rust out than wear out"
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 08-19-2016, 01:03 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
In general the visible part of the caulk is what will deteriorate and it is the part that matters least.
The roof seam is a lap seam and the caulk between the panels is what matters. It's probably fine. I would leave it alone unless there is a problem. You could find someone to test it with a sealtech machine if you are unsure of its condition.
Caulking and Sealants (silicone, parbond, vulkem & more) Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 266 07-01-2017 11:41 AM
sealing / caulking furnace exhaust Casa Rodante Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-02-2014 01:10 PM
Caulking and Sealing crane422 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 11-19-2011 06:27 PM
BellyPan and Wheel Well Caulking/Sealer mbatm01 Belly Pans & Banana Wraps 2 09-07-2004 06:19 PM
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 12:18 PM
