Old 12-05-2009, 07:01 PM   #1
1968 24' Tradewind
Lowesville , Virginia
sealing access doors
Well, down to about 3 small water leaks in the shell....been at this about 3 weeks and each time it rains I spend time inside with a bright light.....had to re-rivet quite a bit and have had real issues around the 2 stationary glasses....but it's getting better!
My last big leak issue is at the access doors and so far I have not found a replacement gasket that will work...this is a 68 Tradewind and had a rubber type gasket in a slot originally.....
I did replace 2 windows (two more to go) supplied by Inland RV with good results...and have gasketed several surviving windows also with good results....cheating with a simple outside "lock" for now. Attaching a before and after...
ID:	92082   Click image for larger version
shimps is offline   Reply With Quote
Old 12-06-2009, 07:44 AM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Great work! Leaks are a pain to find....especially those last little pesky ones!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Need Lock Replacement for 1969 access doors?? tdoescher 1965-1969 Sovereign 2 04-25-2009 05:29 PM
72 Overlander - Need Access Doors NorthernHill Exterior Storage Compartments & Access Doors 7 06-23-2008 02:08 AM
Threshhold and Access doors mbatm01 Repairing/Replacing Floor &/or Frame 12 09-25-2004 07:53 AM
Access Doors and Keys AlanH Doors & Locks 3 06-11-2004 10:36 AM
