Old 03-01-2007, 09:38 PM   #1
Dan Clayton's Avatar
1956 22' Flying Cloud
West Linn , Oregon
Images: 14
Sealing a few small leaks
Anyone know of a product like Creeping Crack Cure that dries faster? I have a few Olympic rivets that are leaking and I want to try sealing them rather then replacing them. Five rivet leaks is not bad after replacing 600 or more rivets. I like Creeping Crack Cure, but it takes a while too dry and it can take a few applications, but it's easy to apply.
Dan Clayton is offline   Reply With Quote
Old 03-02-2007, 04:49 AM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I have used 3M Windshield Sealer with success, it is clear and dries fairly fast. Adheres to the Aluminum well. Good luck, leaks are joy....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-02-2007, 05:16 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Acryl-R..........
................is aluminum colored for a near perfect match, has a wicking action AND is what the factory uses. TRY SOME!!!!!!!!!!!!!
Old 03-02-2007, 06:49 AM   #4
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
I always carry a can of this with me. I purchased the can at the factory store, and they'll fill (and refill it) the can for you there for just a couple more dollars.
That stuff is great for around rivets, windows, doors, etc.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 03-02-2007, 07:24 AM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
I'll have to get me some of that..
www.balrgn.com
Old 03-02-2007, 09:40 PM   #6
1989 29' Excella
afton , Virginia
Creeping Crack Cure
I know a few plumbers in the prone position who could use this!
alumibum is offline   Reply With Quote
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 01:30 PM
Small curbside window davidz71 Upholstery, Blinds, Walls & Interior Finishes 2 09-05-2002 05:09 PM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 07:01 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
