Old 07-21-2013, 12:02 PM   #1
Trying to make memories.
vchatelain's Avatar
1976 27' Overlander
kiln , Mississippi
sealing '75 Overlander Land Yacht w/ Acryl-r ???
Do I run a bead of Acryl r on top of the side mouldings? My rig has a loop that stops on the middle of both sides and the back. The continuous loop makes it look like like 2 strips of mouldings. Also, I am purchasing Silkaflex 505 UV to put in the gap between the awning support and the Airstream. I took out as much of the old silicone that I could. Still have residual in there. Will this work?
I started all this because I have a leak in the back bath window and the front window by the gaucho. I really can't tell where it's coming from. I have an awning on the back
Thanks, I feel like buying a vintage AS was a mistake.
vchatelain is offline   Reply With Quote
A 1963 Overlander named Moonraker! reinergirl 1960 - 1964 Overlander 702 08-28-2017 11:36 AM
Waste tank issues? 1969 Overlander edglenn Plumbing - Systems & Fixtures 4 10-04-2011 10:59 AM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Need Refrigerator Compartment Door for 1972 Overlander jazz1945 Exterior Storage Compartments & Access Doors 1 05-30-2011 02:50 PM
