Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 09-19-2005, 01:21 PM   #1
Devoman
Airstreamin and luvin it
Commercial Vendor
Devoman's Avatar
Profile:  2005 25' Safari
Panama City Beach , Florida
Sealer
I was tooling around the Airstream this morning and noticed that some of the black sealer was coming off.I know this can happen over time but i am needing to know what type of seal this is.Is it the vulkum they use to seal underneather the trailer?If i need to take a pic just let me know.Thanks.
Blue Numbers and Signs
E-Mail Me For Quotes
AIR#8855
WBCCI#6637
Florida Unit #027
Devoman is offline   Reply With Quote
Old 09-19-2005, 02:00 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
DevomanFor small seams use "Par-bond".For large seams use "Vulkem".DO NOT use any form of "silicone sealer" on the exterior.I am not aware of Airstream using any black sealer.Andy
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 09-19-2005, 02:38 PM   #3
StingrayL82
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
Devo,
It might be possible that what you're seeing is sealant that has gotten dirty, which would render it black, but that is only my guess. If you call Ron, at South Jersey RV 856-697-9600, he'll be able to give you a definitive answer to any question you might have. He has been in the business a long time and is such a nice person to deal with. He has the best customer service I've found. I hope that helps you.
Frederic
SSG Frederic Lynes
1971 31' Sovereign, restored
2004 F350 King Ranch
StingrayL82 is offline   Reply With Quote
Old 09-19-2005, 03:52 PM   #4
Devoman
Commercial Vendor
Devoman's Avatar
Pics
Here are some pics to show.The sealer is in four different areas.Hopfully this will give an idea of what i am talking about so you can direct me in the right path to fix this.Thanks
AIR#8855
WBCCI#6637
Florida Unit #027
Old 09-19-2005, 03:56 PM   #5
Devoman
Commercial Vendor
Devoman's Avatar
Pics
Here are the pics.Hope these help.
ID:	14712   Click image for larger version
ID:	14714   Click image for larger version
AIR#8855
WBCCI#6637
Florida Unit #027
Old 09-19-2005, 05:07 PM   #6
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Devoman,
Those joints on my trailer are not caulked...I suspect so water can leak out? If you want to reseal them...use Vulkem or Silkaflex. It is available in a dark color.
Aaron
WBCCI #2449 AIR #2495
Old 09-30-2006, 04:46 PM   #7
Devoman
Commercial Vendor
Devoman's Avatar
Bumpin it up.
I am just trying to figure out if anyone knows what the reason for this stuff is.Is it suposed to be totally seeled or just leave it with the slight openings running on the edges.Thanks all.
AIR#8855
WBCCI#6637
Florida Unit #027
Old 09-30-2006, 08:42 PM   #8
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Devo, Funny you should ask this question today. I've been working on putting the belly pan back on my '73 all day. The 73's have the same gap between the radius pieces in all four corners and the other parts of the banana wrap.
One thing is for certain, if they are not sealed, rain will get in the belly pan. You know what that leads to. Why don't you ask the Airstream Dealer what that stuff is? It looks like it could be Vulkem, but I understand Airstream started using another type of sealant a few years back.
To lodge all power in one party and to leave it there is to insure bad government. -- Mark Twain
www.nesa.org
Air No. 6427
Armstrong RV Air conditioners pap Furnaces, Heaters, Fireplaces & Air Conditioning 45 11-13-2006 09:35 PM
Polish & Sealer PolishGuy The Vendor's Forum 0 08-08-2005 02:24 PM
Removing all of sealer Jalina Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 10-16-2004 12:12 PM
Marker light electrical sealer? TomW Electrical - Systems, Generators, Batteries & Solar 2 01-26-2004 08:22 AM
stove vent installation Martha Roof Vents, Skylights & Fans 4 02-20-2003 09:18 PM
