Old 02-14-2014, 12:08 PM   #1
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Sealants Summary ...
I've been reviewing the forums to determine which sealants to buy for water-sealing maintenance on my new-to-me Airstream. I've come up with the following list of sealants from the posts of others. If anyone has suggestions regarding these sealants, suggestions for better products, or sources for these products, I'd really like to hear them!!
For wheel wells/underbody:
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Windows/Trim
Silkaflex 221 Gray
Parbond Gray or Clear
Small seams (between aluminum panels)
Acryl-R
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 02-14-2014, 12:21 PM   #2
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
Hi Bob, I've bought stuff from VintageTrailerSupply; and in Canada Fastenal carries some as does a store called Cascade in Edmonton.
truckasaurus is offline   Reply With Quote
Old 02-15-2014, 10:09 AM   #3
TinTin's Avatar
Canmore , Alberta
I'm adding to the above list of sealants, based on the thread by sailorii which mentioned that Airstream now recommends AdSeal products.
Vulkem 116
Trempro 635
Adseal Premium Quality Sealant Gray (neutral silicone based)
Roof
Silkaflex 721 White
Adseal Premium Quality Sealant White (neutral silicone based)
Windows/Trim/Rubrail
Silkaflex 221 Gray
Parbond Gray or Clear (small hand tubes)
Acryl-R (small cans)
Bob and Nancy
Old 02-16-2014, 07:42 AM   #4
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Tin, Thanks for the summary of current application and this should be very helpful to folks. Your work here is much appreciated.
This can be a tangle though since some of the caulks that were originally used are simply no longer available. For example I understand that Sikaflex 721UV Gray was used on the windows in the past but is no longer available from Sika but the white is. 721 is a silane terminated polyurethane and evidently has a large dose of UV stabilizer in it (good) for weathering resistance. These hybrid caulks (as 3M calls them) typically cost a bit more. I believe the demise of 721 Gray is what caused the factory to move to the Adseal about three years ago. From my research a couple of years ago, it was evident the Adseal is not a silane terminated polyurethane which makes it different than what is on my trailer.
So when working on my 2010, I try to assure compatibility when doing repairs and that causes a lot of digging for information on my part to be sure that what I put on top is going to be compatible with what is already there.
My perfectionist tendencies probably cause me to overwork this and I will also tell you that caulking is not a pleasurable past time for me and I want to minimize the frequency of rework!
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2019 Canopenian
Alphonse is offline   Reply With Quote
Old 02-16-2014, 07:51 AM   #5
TinTin's Avatar
Canmore , Alberta
Corrected the sealants list again, based on info from Alan that Silkaflex 721 Gray is no longer available.
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Bob and Nancy
Old 02-16-2014, 07:57 AM   #6
Alphonse's Avatar
Lower Alabama , USA
Tin,
The Sikaflex 221 that you had for the windows is available.
My point was that the 221 is just not the same as the 721. It is not a silane terminated polyurethane.
Sorry for the confusion.
Alan
Air #64439
TAC AL-8
2019 Canopenian
Old 02-16-2014, 08:04 AM   #7
TinTin's Avatar
Canmore , Alberta
My mistake, Alan. Corrected the list.
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
Bob and Nancy
Old 02-19-2014, 09:56 AM   #8
chilipepper's Avatar
1971 27' Overlander
Dickinson , North Dakota
Thanks for the list and this will be a great resource. Since we are still in the middle of winter up here I'm wondering what temperatures these can be applied in as well as maybe an ideal application temperature? I have a couple of projects that could use some of these sealants and the daytime high temps here are barely touching freezing. Can I still effectively use any of these or do I need to wait for warmer weather?
chilipepper is offline   Reply With Quote
Old 02-19-2014, 01:04 PM   #9
TinTin's Avatar
Canmore , Alberta
I'm far from expert in this chilipepper, but I'd wait until the temperatures are at least 50F. I've checked a couple of tubes of silicone II that I have here, they say 5C before application (about 40F). The acrylics and polyurethanes probably want temperatures higher than 50F to insure that the products are pliable enough for easy (and tidy) application.
Bob and Nancy
Old 02-19-2014, 04:00 PM   #10
2010 25' FB Flying Cloud
Davenport , Iowa
I just got my "Capt. Tolley"s Creeping Crack Cure" that was suggested in another thread to seal the rivets.
Airtandem is online now   Reply With Quote
Old 02-19-2014, 07:00 PM   #11
TinTin's Avatar
Canmore , Alberta
Added rivet sealer based on Airtandem's post:
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
Rivet sealer
Captain Tolley's Creeping Crack Cure
Bob and Nancy
Old 02-19-2014, 07:57 PM   #12
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
I've used these products with good success:
LOCTITEŽ PLŽ S30 POLYURETHANE ROOF & FLASHING SEALANT
Loctite PL S30 Polyurethane Roof & Flashing Sealant from Loctite Adhesives
LOCTITEŽ PLŽ S40 POLYURETHANE WINDOW DOOR AND SIDING SEALANT
Loctite PL S40 Window Door and Siding Sealant from Loctite Adhesives
They're both polyurethane. They take a couple of days to dry (cure) though, so apply when the weather is expected to be fair.
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 02-19-2014, 08:04 PM   #13
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
This is such a great post! I've printed it and will keep it handy....I keep a supply of Parbond, Silkaflex, Vulkem and Trempro handy. Also a roll of butyl tape that I've used on a couple of occasions. A spray can of the Pewter touch-up paint also comes in handy.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-19-2014, 09:10 PM   #14
1965 20' Globetrotter
Sacramento , California
Images: 13
As an owner of a vintage AS (1965), are these sealants also recommended? If not, any recommendations?
"It's always something!" --Roseanne Roseannadanna
jakes_mama is offline   Reply With Quote
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
insulation, sealants and leaks Pablito Interior Restoration Forum 5 04-21-2013 10:57 AM
Summary Of Full-Timing Considerations Mr.Bill Full-Timing 57 12-03-2011 09:44 PM
Sealants Captain Hank Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-31-2011 06:31 AM
