Old 04-20-2015, 03:47 AM   #121
sandlapper's Avatar
1993 34' Excella
York , South Carolina
This is a great thread, I have been following it from the beginning. Nice work TinTin.
Nothing I can add except that most chemical strippers contain wax or paraffin that skims over to prevent evaporation of the product before it can do it's job. The residual wax might be a problem for adhesion of the new sealant unless washed off with a good clean solvent, perhaps lacquer thinner.
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
sandlapper is offline   Reply With Quote
Old 05-18-2015, 12:38 PM   #122
Danny Bell's Avatar
1966 28' Ambassador
Colville , Washington
Very informative thread ! Until this thread I hadn't given freshening up ALL the seals. Our trailer has a variety of different sealants on it from P.O.'s. A gray pliable sealant around the windows, except one has a very hard white (Sikaflex I presume) around it. A very thin gray on all seams and a hard silver type around the a/c and vents. All of my rivets are tight. Other than a small leak around the Astradome vent/skylight, we have had no leaks.
Questions...
If I re-seal everything now, what's going to happen when I polish the trailer next summer ? Should I seal after the polishing or is it a mute point ?
Danny
Danny Bell is offline   Reply With Quote
Old 05-18-2015, 01:06 PM   #123
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Originally Posted by Danny Bell View Post
Questions...
Danny
If I was going to polish I would remove the old caulking, polish then recaulk everything. I think the job would look better in the end.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-28-2015, 04:42 PM   #124
Westminster , Colorado
Originally Posted by reinergirl View Post
I used Citrastrip to take off all the black glue and then used Trempro 635 to
"paint" all the seams I could reach.
I thought someone said that the Trempro 635 turns to dust....is that just when it's exposed to light?
I am lost on this. I'm assuming that the seams are to be sealed from the exterior. But is there something that is supposed to go where the black tar went? Or do I leave the rivets and where the frame, and the inside of the exterior skin meet, exposed.
This is such an informative thread! Thanks for everyone's contributions!
painterfam is offline   Reply With Quote
Old 05-28-2015, 05:21 PM   #125
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I put the Acryl with pump into a ziplock bag along with wire in the spout tip. Always works!
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-15-2015, 12:17 PM   #126
Cardinal283's Avatar
Dallas , Texas
Has anyone used Dymonic 100 from Tremco? The local Tremco distributor said that it's like vulkem but it has more flex. According to the tube it has 100% stretch and 50% compression before failure. If I'm reading it correctly. Click image for larger version
Name:	ImageUploadedByAirstream Forums1434392217.608693.jpg
Cardinal283 is offline   Reply With Quote
Old 06-16-2015, 11:12 AM   #127
insearchoffun
exallen's Avatar
Mesa , Arizona
I see where sikaflex (not silkaflex) 221 gray is available from Amazon, but provided by Orange County Airstream.
insearchoffun
exallen is offline   Reply With Quote
Old 06-16-2015, 11:24 AM   #128
Rich W's Avatar
I'm In , Kentucky
When I was at the Airstream facility they had sikaflex 221. Some tubes are marked "black" while others had no designation. Is the sikaflex 221 default color gray?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 06-16-2015, 02:36 PM   #129
Naples , Florida
No, you have to look at the plunger end to find the color on some tubes of SikaFlex.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
Old 07-10-2015, 09:45 AM   #130
1973 31' Excella 500
townsend , Georgia
Sikaflex 221
I google sikaflex and homedepot has this product listed. Is this the same sikaflex 221 that everyone has been talking about?
Sikaflex 10 fl. oz. Crack Sealant-427706 - The Home Depot
deaun99 is offline   Reply With Quote
Old 07-10-2015, 01:06 PM   #131
Naples , Florida
NO! The only SikaFkex product discussed here as a sealant/adhesive is 221. Any other Sika product is not the same and has different properties.
Lew Farber
541-490-6357
lewster
Old 07-12-2015, 06:08 AM   #132
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I suspect one or both of my door hinges may be leaking. What do I use to seal? I have Adseal gray and Acryl-R. Do I need the remove one hinge at a time to perform this job or do I just need to remove the mounting scores one at a time and coat with Adseal and screw back in? I guess I just peel off the silver trim cover to access the screws that mount the hinge?
Kelvin
Old 07-12-2015, 07:23 AM   #133
dznf0g's Avatar
Oswego , Illinois
Kelvin, If you loosen those screws, you will be performing surgery on the interior skins to get to the nuts that hold the hinges on. I wouldn't even tempt myself to touch those screws. I would clean the hinge/skin joint very well, tape off a thin gap at the joint and use either Acryl-R or Parbond. I use parbond for this type of joint.
-Rich-
Old 07-12-2015, 07:51 AM   #134
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Do those screws ever need to be checked for tightness? Will the nuts inside turn or do they have lock washers?
Kelvin
Old 07-12-2015, 02:08 PM   #135
1998 30' Excella 1000
Livingston , Texas
Kelvin, there are several posts on this problem. Here is one of mine:
http://www.airforums.com/forums/f453...ge-122387.html
There are several others, with even more info, just search for them.
Siegmann is offline   Reply With Quote
Old 07-15-2015, 08:25 PM   #136
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
kind of skimmed the last page but today I was picking up some stuff and the vendor had Vulkem 116 but they also had a BASF product which they claimed was the same, so I picked up a tube to check out. Here's the link in case anyone else has tried it already.
MasterSeal NP 1
truckasaurus is offline   Reply With Quote
Old 07-15-2015, 08:52 PM   #137
Livingston , Texas
Truckasurus, I used a high performance polyurethane sealant by BASF called Sonolastic NP1 around my wheel wells three years ago. So far it seems as durable as the original factory Vulkem/Sikaflex.
Old 07-15-2015, 08:54 PM   #138
1960 33' Custom
Athens , Georgia
Cool. That's the same stuff (just rebranded I believe). Nice to find something local to me at last.
Old 10-07-2015, 05:13 PM   #139
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
What is the proper cleaner before applying sikaflex? I KNOW it's not alcohol!
Thanks!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 10-07-2015, 05:25 PM   #140
Senior Member
sheriff1's Avatar
Sparks , Nevada
More research says acitone?
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
insulation, sealants and leaks Pablito Interior Restoration Forum 5 04-21-2013 10:57 AM
Summary Of Full-Timing Considerations Mr.Bill Full-Timing 57 12-03-2011 09:44 PM
Sealants Captain Hank Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-31-2011 06:31 AM
