02-14-2014, 12:08 PM
2009 23' FB Flying Cloud
Canmore
, Alberta
Sealants Summary ...
I've been reviewing the forums to determine which sealants to buy for water-sealing maintenance on my new-to-me Airstream. I've come up with the following list of sealants from the posts of others. If anyone has suggestions regarding these sealants, suggestions for better products, or sources for these products, I'd really like to hear them!!
For wheel wells/underbody:
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Windows/Trim
Silkaflex 221 Gray
Parbond Gray or Clear
Small seams (between aluminum panels)
Acryl-R
02-14-2014, 12:21 PM
1960 33' Custom
Athens
, Georgia
Hi Bob, I've bought stuff from VintageTrailerSupply; and in Canada Fastenal carries some as does a store called Cascade in Edmonton.
02-15-2014, 10:09 AM
Canmore
, Alberta
I'm adding to the above list of sealants, based on the thread by sailorii which mentioned that Airstream now recommends AdSeal products.
Vulkem 116
Trempro 635
Adseal Premium Quality Sealant Gray (neutral silicone based)
Roof
Silkaflex 721 White
Adseal Premium Quality Sealant White (neutral silicone based)
Windows/Trim/Rubrail
Silkaflex 221 Gray
Parbond Gray or Clear (small hand tubes)
Acryl-R (small cans)
02-16-2014, 07:42 AM
2010 28' Flying Cloud
Lower Alabama
, USA
Tin, Thanks for the summary of current application and this should be very helpful to folks. Your work here is much appreciated.
This can be a tangle though since some of the caulks that were originally used are simply no longer available. For example I understand that Sikaflex 721UV Gray was used on the windows in the past but is no longer available from Sika but the white is. 721 is a silane terminated polyurethane and evidently has a large dose of UV stabilizer in it (good) for weathering resistance. These hybrid caulks (as 3M calls them) typically cost a bit more. I believe the demise of 721 Gray is what caused the factory to move to the Adseal about three years ago. From my research a couple of years ago, it was evident the Adseal is not a silane terminated polyurethane which makes it different than what is on my trailer.
So when working on my 2010, I try to assure compatibility when doing repairs and that causes a lot of digging for information on my part to be sure that what I put on top is going to be compatible with what is already there.
My perfectionist tendencies probably cause me to overwork this and I will also tell you that caulking is not a pleasurable past time for me and I want to minimize the frequency of rework!
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
02-16-2014, 07:51 AM
Canmore
, Alberta
Corrected the sealants list again, based on info from Alan that Silkaflex 721 Gray is no longer available.
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
02-16-2014, 07:57 AM
Lower Alabama
, USA
Tin,
The Sikaflex 221 that you had for the windows is available.
My point was that the 221 is just not the same as the 721. It is not a silane terminated polyurethane.
Sorry for the confusion.
Alan
Air #64439
02-16-2014, 08:04 AM
Canmore
, Alberta
My mistake, Alan. Corrected the list.
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
02-19-2014, 09:56 AM
1971 27' Overlander
Dickinson
, North Dakota
Thanks for the list and this will be a great resource. Since we are still in the middle of winter up here I'm wondering what temperatures these can be applied in as well as maybe an ideal application temperature? I have a couple of projects that could use some of these sealants and the daytime high temps here are barely touching freezing. Can I still effectively use any of these or do I need to wait for warmer weather?
02-19-2014, 01:04 PM
Canmore
, Alberta
I'm far from expert in this chilipepper, but I'd wait until the temperatures are at least 50F. I've checked a couple of tubes of silicone II that I have here, they say 5C before application (about 40F). The acrylics and polyurethanes probably want temperatures higher than 50F to insure that the products are pliable enough for easy (and tidy) application.
02-19-2014, 04:00 PM
2010 25' FB Flying Cloud
Davenport
, Iowa
I just got my "Capt. Tolley"s Creeping Crack Cure" that was suggested in another thread to seal the rivets.
02-19-2014, 07:00 PM
Canmore
, Alberta
Added rivet sealer based on Airtandem's post:
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
Rivet sealer
Captain Tolley's Creeping Crack Cure
02-19-2014, 08:04 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
This is such a great post! I've printed it and will keep it handy....I keep a supply of Parbond, Silkaflex, Vulkem and Trempro handy. Also a roll of butyl tape that I've used on a couple of occasions. A spray can of the Pewter touch-up paint also comes in handy.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
02-19-2014, 09:10 PM
1965 20' Globetrotter
Sacramento
As an owner of a vintage AS (1965), are these sealants also recommended? If not, any recommendations?
Jayne & Brian
Luna, 1965 Globe Trotter 20’ Twin
2018 Toyota Sequoia
02-19-2014, 09:36 PM
Canmore
, Alberta
Added the Loctite sealants based on acstokes recommendations.
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Loctite® PL® S30 Polyurethane Roof and Flashing Sealant
Silkaflex 221 Gray
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Rivet sealer
03-10-2014, 09:22 AM
Canmore
, Alberta
Added exterior lights to group 4
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
Small seams (between aluminum panels)/Exterior Lights
Rivet sealer
10-07-2014, 03:38 PM
Canmore
, Alberta
Added Dicor to roof sealants
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Dicor self-levelling sealant
Silkaflex 221 Gray
Rivet sealer
11-15-2014, 06:52 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Great thread Bob, very useful for a newb.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
11-26-2014, 01:55 PM
1972 31' Sovereign
Valparaiso
, Indiana
This is so helpful TinTin. Thanks so much for posting
12-04-2014, 05:42 PM
Canmore
, Alberta
(removed LocTite PLS30 from roof sealants)
Vulkem 116
Trempro 635
Roof:
Silkaflex 721 White
Windows/Trim/Rubrail:
Silkaflex 221 Gray
Small seams (between aluminum panels)/Exterior Lights:
Rivet sealer:
