Old 10-07-2015, 06:56 PM   #141
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by sheriff1 View Post
What is the proper cleaner before applying sikaflex? I KNOW it's not alcohol!
Thanks!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
Previous posts suggested Eternabond spray cleaner
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 10-07-2015, 07:03 PM   #142
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Just ordered some up.
Thanks!
sheriff1 is offline   Reply With Quote
Old 10-07-2015, 08:18 PM   #143
lewster's Avatar
Naples, FL , Hood River, OR
Carb cleaner works well also.
Old 10-07-2015, 08:23 PM   #144
CRH
1995 25' Excella
xxxxx , xxxxxx
I use mineral spirits.
CRH is offline   Reply With Quote
Old 10-07-2015, 08:38 PM   #145
lewster's Avatar
That works also.....just NO ALCOHOL!!! (save that for drinking!!)
Old 10-16-2015, 11:17 AM   #146
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Silicone or not?
I am refreshing this thread with a dumb question. I have read on this forum, over and over, not to use silicone caulks on my Airstream. Why not? In particular the roof caulk is perplexing. Airstream sent me a tube of ADSEAL, which is a Silicone RTV product and that is what they are using on the roofs now. Hard to find any info on it, maybe made by ADFAST in Canada. No MSDS easily available on the web but AS does list it as silicone. I can't even find any place to buy it except Airstream and some places that stock Airstream products. I'd rather use a polyurethane like 221 but there isn't going to be any compatibility between a silicone and a polyurethane. I'm going to patch for now but I am looking at some major caulking work next year. Thanks
Larry
lsbrodsky is offline   Reply With Quote
Old 10-16-2015, 03:59 PM   #147
lewster's Avatar
There's no compatibility between silicone and ANY other product......even more of the same silicone-based product.
Airstream is in for a HUGE SURPRISE when the AdSeal starts to leak and they can't add more over it. Let's face it...... Many of their 'better ideas' like battery burner converters, weak to horrible solar packages and wiring that's just barely passable work great.......NO? :-))
I'm such a big fan of SikaFlex products because over the last 15 years, I have had to repair and restore many types of RV roofing and the only product that works consistently without failures for me is SikaFlex.
Another great product is #1021 from Alpha Systems, but is only available within the industry. This is a self-leveling sealant which I believe is a silane terminated polymer. This takes about a week to cure, but stiffens into a solid, rubbery covering that bonds very well to any substrate. THIS IS WHAT AIRSTREAM SHOULD B E USING ON THE ROOF SEAMS!!! I see it with increasing frequency on the more expensive diesel rigs.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 10-16-2015, 05:49 PM   #148
lsbrodsky's Avatar
Thanks, Lew. I guess I am in for a major Adseal removal chore next year. I'll recaulk with Sikaflex.
Larry
Old 10-17-2015, 08:15 AM   #149
KYAirstream's Avatar
Northeastern , Kentucky
Lew- how does this Sikaflex product compare to the one you routinely use?
Name:   ImageUploadedByAirstream Forums1445091271.322790.jpg
KYAirstream is offline   Reply With Quote
Old 10-17-2015, 08:55 AM   #150
lewster's Avatar
Don't know as I have never used it. If it's not too expensive, buy a tube and give it a trial run on something other than the AS....like a couple of wood blocks or a piece of plastic and aluminum scrap to see how well it bonds. You also might give the tech dep't. at Sika Corp. a call and pose that question to them: 800-993-7452
The only Sika products that U use on a regular basis are 221 and 715 and the new Alpha Systems product for large area sealing.
Old 10-20-2015, 10:56 AM   #151
1998 30' Excella 1000
Livingston , Texas
Four years ago I noticed small gaps opening up in the Vulkem at the joints in my wheel wells/bottom trim/banana wrap. Instead of ripping out the old Vulkem, I decided to just fill the gaps. I used BASF Sonolastic NP1 High Performance Polyurethane Sealant to fill the gaps after cleaning the area with 90% isopropyl alcohol (before I knew that alcohol was contraindicated under polyurethane/Sikaflex). Well, 4 years down the road, and the NP1 is still firmly bonded to the ABS (banana wrap), aluminum and the original Vulkem!
Siegmann is offline   Reply With Quote
Old 10-26-2015, 10:11 PM   #152
nickclifford's Avatar
1972 31' Sovereign
felton , California
great post but i must have missed this , the product Sikaflex 715 Roof Seal 10.14 oz 017-187690 as recommended for roof vent sealing is WHITE !! was assuming that being an airstream forum and product recommended for airstreams would have been grey colored! maybe it's considered ok or better to use white sealants>? any thoughts most appreciated. THX
Just bought 3 tubes
nickclifford is offline   Reply With Quote
Old 10-26-2015, 10:18 PM   #153
1972 31' Sovereign
felton , California
Just bought 3 tubes
having said that my roof vents are white, well two of them are and one is original aluminum..
question on removing the old caulking, someone said removing the old stuff is best ... omg, that's a lot of work, i've tried several times and have removed most, I'd say about 80% using paint remover (nasty stuff). I've cleaned off around the a/c and the roof vents hoping to find a couple of leaks... so question is, is it ok to apply the 715 over any remaining caulking at this stage ?
thanks, Nick
Old 10-27-2015, 10:02 AM   #154
1972 31' Sovereign
felton , California
Originally Posted by TinTin View Post
Thanks Lew!! Changes made according to Lewster's recommendations.
For wheel wells/underbody:
Vulkem 116
Trempro 635
Sikaflex 221 Black (use Eterna Bond spray cleaner to prepare surface)
Adseal Premium Quality Sealant Grey
Roof:
Sikaflex 221 White (for roof seams ... use Eterna Bond spray cleaner to prepare surface)
Sikaflex 715 (around fans, vents, skylights ... self-levelling)
Adseal Premium Quality Sealant White
Dicor self-levelling sealant
Windows/Trim/Rubrail:
Sikaflex 221 Grey (use Eterna-Bond spray cleaner to prepare surface)
Parbond Grey or Clear (small hand tubes)
LoctiteŽ PLŽ S40 Polyurethane Window Door and Siding Sealant
Small seams (between aluminum panels)/Exterior Lights:
Acryl-R (small cans)
Rivet sealer:
Captain Tolley's Creeping Crack CureParbond Gray or Clear (small hand tubes)
hello TinTin, so you're suggesting white is ok for top vents etc of an AS? would grey not be more suited for appearance sakes? or white is better for heat deflection ? thanks
Old 10-27-2015, 01:24 PM   #155
Senior Member
sheriff1's Avatar
Sparks , Nevada
The newer AS have white roofs.
Old 11-11-2015, 09:31 AM   #156
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have "discovered" a way to "keep" open tubes of sealant for weeks!!
I use a connector like the one in the attached picture over the open tip.
First I put the crimp connector over the end of the dispense tube then shoot sealant in until it squirts out.
I have kept and reused the tubes multiple times and all you do is twist off the connector and start using it.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-11-2015, 12:10 PM   #157
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Also you can keep them in the freezer. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 11-11-2015, 02:54 PM   #158
TinShack's Avatar
2005 28' Safari S/O
That works. If I haven't cut off too much of the sealant tube tip, I use a large (red) wire nut instead and it screws right on to the tip. This keeps it for quite a while and you can wrap it with a piece of electrical tape for added longevity.
Steve
Old 11-12-2015, 07:38 AM   #159
2003 31' Classic
Terra Alta , West Virginia
Those are good ideas. I will try that. I have always used various size bolts to thread into the tip. That works too. I seldom use a whole tube of any material at one time.
wvstreamer is offline   Reply With Quote
Old 11-12-2015, 08:38 AM   #160
Arrowstream's Avatar
Columbia , South Carolina
Little Red Caps
Arrowstream is offline   Reply With Quote
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
insulation, sealants and leaks Pablito Interior Restoration Forum 5 04-21-2013 10:57 AM
Summary Of Full-Timing Considerations Mr.Bill Full-Timing 57 12-03-2011 09:44 PM
Sealants Captain Hank Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-31-2011 06:31 AM
