Old 04-14-2015, 06:07 PM   #101
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Most professional caulking companies I have dealt with use kerosene to cut/trowel poly-based sealants while wet. I use alcohol to cut/trowel silicone sealants while wet. Most of these sealants are solvent-immune once cured.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 04-14-2015, 06:10 PM   #102
lewster's Avatar
Naples, FL , Hood River, OR
Just a quick note......NEVER use alcohol as a cleaning/prep agent if you are intending to use SikaFlex polyurethane, as it inhibits it's adhesive properties (per Sika Corp.)
Old 04-14-2015, 06:19 PM   #103
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Only alcohol w/ silicone...kerosene w/ poly. Not as prep agents but to trowel/cut (i.e. clean up beads). Silicone has limited uses on AS trailers to begin with. I would only use silicone for glass (windows) and a few interior applications.
Old 04-15-2015, 06:41 AM   #104
lewster's Avatar
I just use a rubber-gloved finger for smoothing. No solvents ever.
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 04-15-2015, 11:25 PM   #105
GlamperGirl
I love Sikaflex
thumbelinadj is offline   Reply With Quote
Old 04-16-2015, 07:53 AM   #106
1998 30' Excella 1000
Livingston , Texas
I'm curious. Why would using alcohol to clean the seam before caulking be bad? Seems it would evaporate completely and not affect the later application of the caulk.
Siegmann is offline   Reply With Quote
Old 04-16-2015, 10:38 AM   #107
lewster's Avatar
Alcohol must have some residual that remains on the substrate which then interferes with the bonding process of the polyurethane.
If the tech department of the manufacturer of SikaFlex says not to use it.........I DON'T!!
I use cases of the stuff and have never had issues while following the company's application guidelines.
If you are still unsatisfied with this answer, I would suggest a call to the chemists at Sika Corp. for their reasoning.
Lew Farber
541-490-6357
Old 04-16-2015, 10:57 AM   #108
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I used Alcohol in a bunch of places before I saw the warning hear, as I might of stated earlier in this thread. For the most part, all my Silkaflex is still solid. And had no issues to my knowledge bonding. We'll see how it holds up, as only time will tell.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 04-16-2015, 11:07 AM   #109
2007 22' International CCD
It's possible that someone used rubbing alcohol instead of straight isopropyl alcohol. Rubbing alcohol has some oil in it and will leave residue for sure.
Best to not use alcohol at all to avoid any chance of an issue. I likely to assume Sikaflex manufacturer knows what they are talking about, and I DO know Lew does...
rmkrum is online now   Reply With Quote
Old 04-16-2015, 06:36 PM   #110
Livingston , Texas
I could see the issue with rubbing/isopropyl... what about methanol?
Old 04-16-2015, 07:54 PM   #111
lewster's Avatar
Listen............
Some of you can of course, do as you like with your trailers. I use Sika products by the case in professional applications on a daily basis and NOT as a hobbyist or occasional user, so when the manufacturer says NO ALCOHOL...........I assume they have done the research to arrive at their conclusions and they mean NO ALCOHOL......... whether methanol, isopropyl or rubbing. There are no exceptions listed!!!!! Is this concept that difficult to grasp and understand?????????
If your application of said product fails.....it's what you did and you take the time to rectify your error. If mine fails on YOUR trailer.........it not only reflects on me, but also costs me to remove and replace the product.
I DON'T SECOND GUESS THE PRODUCT DIRECTIVES
And BTW, I'm done with my contributions to this thread!
Old 04-17-2015, 06:10 AM   #112
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
lewster thank you for your post. I am new to airstream and read these posts to learn more about maintaining my 2015 Sport. I for one would not disagree having your credentials you should know. When I see your post I always read it carefully. Thank you for contributing.
Ron
16' Sport 2015
Ron
Ron A is offline   Reply With Quote
Old 04-17-2015, 07:15 AM   #113
Nomadic , USA
I just wish I had seen the warnings before I went about cleaning a bunch of areas on the back pano's with it. I have now switched though since I started caulking the roof and did my solar. I just hope the pano windows stay fine. I'm starting to be a fan of the Silkaflex.
Old 04-18-2015, 08:50 AM   #114
GlamperGirl
My belly pan is held together with Sikaflex. I love that stuff. It's not coming off. Ever
Old 04-18-2015, 11:54 AM   #115
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I like the SikaFlex, and have also used "Quikrete® Polyurethane Non-Sag Sealant". I sent them an email asking about compatibility with aluminum and their response was, "Quikrete® Polyurethane Non-Sag Sealant is compatible with aluminum."
Makes sense.... it's also used to seal around aluminum-framed windows and building materials.
It worked well between the frame and body panels on our Avion. The non-sag properties are very handy.
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-18-2015, 02:20 PM   #116
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Originally Posted by belikethefox View Post
Tin Tin: On your most recent list, you have multiple options per section.
Are they all comparable/interchangeable?
Sorry BLTF, only now noticed your post. Regarding interchangeability, my opinion would be that they are. Of course it's good practice to remove as much of the old caulk as possible before adding new.
Regarding compatibility, they are largely polyurethane caulks, so in general they should be compatible. Can't vouch for that though. I have a few favourites that I have been able to source locally or online, and tend to stick with them. I use Parbond a LOT, like the way it goes on and the small bead.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 04-18-2015, 03:37 PM   #117
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Airstream Store Sealant Kit
I noticed the the Airstream Store the sealant kit was on sale so figured it would be a good start to my sealant collection.
28430W – 16 oz can of Acryl-R Seam Sealer and Applicator Head. Use to seal all metal to metal seams, including but not limited to, segment seams, sides and bottom of riveted frame windows, compartment door frames, marker lights, and tail lights; any where a fine bead of gray sealant is required.
365330-01 – 10 oz tube of AdSeal Premium Quality Sealant Adhesive – White. Use to seal all exterior roof components (on travel trailers with white roof sheets)
365330-03 – 10 oz tube of AdSeal Premium Quality Sealant Adhesive – Gray. Use to seal eyebrows of riveted frame windows and main door; any where a thicker bead of gray sealant is required.
360180-04 – 10 oz tube of Sikaflex 221 Multi-Purpose Polyurethane Sealant – Black. Use to seal below the rubrail on trailers 1984-present with pewter gray underbelly, also on Safari black trailer windows.
When using the Acryl-R applicator how do you clean the applicator after use?
Kelvin
Old 04-19-2015, 06:49 AM   #118
2005 30' Classic
Burlington , Ontario
Kelvin
Kelvin,
I have had a can that I have been using for at least four years. All I ever have done when finished using it is to clean off any external product and then stick a piece of wire in the end of the nozzle. It has always worked immediately next time I used it.
If I remember, the gun originally came with a short wire, maybe an inch long, with a loop on the end. That got lost somewhere along the line and I now have a piece os stainless wire several inches long that I use.
I don't think you will have any problem.
Brian.
Old 04-19-2015, 07:10 AM   #119
dznf0g's Avatar
Oswego , Illinois
Lew Farber
541-490-6357
Ditto....after taping off. With Parbond you have to smooth just a couple feet at a time....quickly...it skins over rapidly. Remove tape quickly as well.
-Rich-
Old 04-20-2015, 01:24 AM   #120
cuyeda's Avatar
Long Beach , California
Originally Posted by reinergirl View Post
I used Citrastrip to take off all the black glue and then used Trempro 635 to
"paint" all the seams I could reach.
I am at this point after removing interior skins on a 1958 Airstream. This seams haha seems like an extreme to remove the black spray on goo. While I understand starting with a clean surface is for better adhesion, can the Trempro 635 be applied over the top?
While I don't want to cut corners, this is a lot of work! Is there a seam sealer that can be applied over the black stuff? Is removal (Citrastrip) a method that most here use for seam sealing, and over the backside of buck or olympic rivets?
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Xplore
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
insulation, sealants and leaks Pablito Interior Restoration Forum 5 04-21-2013 10:57 AM
Summary Of Full-Timing Considerations Mr.Bill Full-Timing 57 12-03-2011 09:44 PM
Sealants Captain Hank Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-31-2011 06:31 AM
