Old 01-03-2015, 07:34 PM   #61
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
It is extremely expensive and you need a special sealant gun along with a special mixer to use. If I didn't have access I would use one of polyurethanes.
Believe it or not I obtained my sealant gun an mixer from the Boeing surplus store many years ago when we did a project out of Paine Field.
Old 01-03-2015, 07:42 PM   #62
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I would suggest that EternaBond Alumibond be added to the list of products to use on the roof to eliminate leaks. Great product to use on roof seams, around vents and stacks, etc.
EternaBond AlumiBond
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 01-03-2015, 08:06 PM   #63
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
-added EternaBond AlumiBond tape to roof sealants
For wheel wells/underbody:
Vulkem 116
Trempro 635 Grey
Sikaflex 221 Black (use Eternabond spray cleaner to prepare surface)
Adseal Premium Quality Sealant Grey
Roof:
Sikaflex 221 White (for roof seams, seals and bonds. Use Eternabond spray cleaner to prepare surface)
Sikaflex 715 (around fans, vents, skylights ... self-levelling)
Adseal Premium Quality Sealant White
Dicor self-levelling sealant
EternaBond® AlumiBond (alum. backed sealing tape, 2", 3", 4", and 6" wide)
Windows/Trim/Rubrail/Exterior Lights:
Sikaflex 221 Grey (seals and bonds. Use Eternabond spray cleaner to prepare surface)
Parbond Grey or Clear (small hand tubes, prep and clean-up use cosmoline remover)
Trempro 635 Grey
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Lexel™ Clear
Small seams (between aluminum panels):
Acryl-R (available in cans from Airstream store. Use applicator or disposable syringes to apply)
Rivet sealer:
Captain Tolley's Creeping Crack Cure
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 01-05-2015, 11:29 AM   #64
Trailer's Avatar
2015 25' FB Flying Cloud
Palm Springs , California
I see you are a "Rivit Master." What feats do you have to do to earn that? How are the different levels determined? Sorry to bother you.
Bill
Trailer is offline   Reply With Quote
Old 01-05-2015, 12:14 PM   #65
TinTin's Avatar
Canmore , Alberta
The avatar 'titles' simply reflect the number of posts you've made on the forum.
Bob and Nancy
Old 01-05-2015, 01:04 PM   #66
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
WHAT??? They made me take a written test and then perform a comprehensive practical exam, AFTER 80 hours of OJT!
-Red, feeling cheated...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 01-05-2015, 04:18 PM   #67
TinTin's Avatar
Canmore , Alberta
That written exam was a toughie, wasn't it?
Bob and Nancy
Old 01-05-2015, 04:28 PM   #68
Panama Red's Avatar
Obrien , Florida
Barely squeaked out the 70% minimum I needed.
-Red, Mr Skin of His Teeth...
Old 01-05-2015, 05:16 PM   #69
lewster's Avatar
Naples, FL , Hood River, OR
Just a note on my experience with Eternabond sealant tapes.
They seem to apply well, are super sticky at first and seem to be bullet-proof after application. But having had reports of continual leaking on SOB roofing a year or 2 down the road, the situations have ALWAYS led to the Eternabond tapes' adhesive failing!
When I started as an RV tech, I used to use the stuff by the case all the time, but after seeing the failures and having to deal with the massive cleanup of the Eternabond adhesives, I discontinues using them totally.
My go to adhesive sealants are from Sika and include SikaFlex 221 in the many colors available and the 715 for self leveling use (as mentioned on the list). I have recently started testing and using a similar high solids, self-leveling adhesive/sealant from a US company called Alpha Sealants. This is not presently available to the general public, and takes 3-5 days to fully cure, but it IS available in black, white, grey and off-white. Very similar to SikaFlex 751 but with more body.
I've shot a couple of roofs with the Alpha sealants and will wait another couple of weeks to do a final inspection, but I will never use Eternabond again!!
In fact, I have several rolls available for postage!!!!! PM me for details.
As always....YMMV!
Old 01-05-2015, 05:36 PM   #70
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
What temperature ranges?
What temperature ranges do these various products work at? I don't have any immediate urge to go out an seal something, but if I did, what works in the winter? It was 4 degrees F this morning at 9:00 (and 56 two hours later...).
SSquared is offline   Reply With Quote
Old 01-05-2015, 07:20 PM   #71
TinTin's Avatar
Canmore , Alberta
I'd wait until the warm days of spring to apply any of these sealants. Unless you have a warm building you could use for a few days.
Bob and Nancy
Old 01-05-2015, 10:08 PM   #72
Trailer's Avatar
The physical was a trhill......
Old 01-11-2015, 09:49 AM   #73
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Aluminum Pigmented Gutterseal
Here is what I used on some of my small overlapping panel seams, all the eyelids above the door and windows, as well as the seam around the door where the exterior panels meet the cast aluminium door frame. It applies a nice rounded convex bead from a metal squeeze tube to the surface which after drying overnight changes to be a tidy sucked in concave bead.
It is weird to work with though, there is zero tooling time... as you are laying the bead the product skins over within an inch of leaving the tube ( I discovered this when I wobbled off course a bit and tried to go back over where I had been) but with a steady enough hand to lay a straight line it looks amazing and blends right in to the trailer. One tube has been enough to do my entire 23' trailers seams.
Here is a cut and paste on the product I copied from Vintage Trailer Supplies website...
Aluminum Pigmented Gutterseal is one of the more difficult trailer restoration products to find because it is designed--as the name suggests--for the aluminum gutter industry.*
Unlike Vulkem or Parbond, Gutterseal it has a tendency to slightly wick into seams, making it a popular choice for sealing panel lap seams.
5 ounce squeeze tube does not require a caulking gun.
Contains Acetone, Methyl Acetate and Tert-Butyl Acetate. See MSDS.
thesignlady is offline   Reply With Quote
Old 01-11-2015, 10:14 AM   #74
1965 26' Overlander
Penticton , British Columbia
Great Info
This stream couldn't have come along at a better time..... was in the 65 yesterday and snow was melting and found all the leaks (the puddles on the inside helped) ...... know what I am going to be doing in the spring.
Thank you for all the valuable information all in one spot!!!
cndsilvrgurl is offline   Reply With Quote
Old 01-11-2015, 10:41 AM   #75
TinTin's Avatar
Canmore , Alberta
(added Aluminum Pigmented Gutterseal)
Vulkem 116
Trempro 635 Grey
Roof:
Trempro 635 Grey
Lexel™ Clear
Rivet sealer:
Bob and Nancy
Old 01-12-2015, 09:17 AM   #76
TinTin's Avatar
Canmore , Alberta
(moved Aluminum Pigmented Gutterseal to 'small seams')
Vulkem 116
Trempro 635 Grey
Roof:
Trempro 635 Grey
Lexel™ Clear
Rivet sealer:
Bob and Nancy
Old 01-13-2015, 06:51 AM   #77
1981 31' Excella II
New Market , Alabama
I would put that Lexel on the roof as well. It does not break down like the polyurethane sealants.
Perry
Old 01-13-2015, 09:20 AM   #78
TinTin's Avatar
Canmore , Alberta
(added Lexel to Roof sealants)
Vulkem 116
Trempro 635 Grey
Roof:
Lexel™ Clear
Trempro 635 Grey
Lexel™ Clear
Rivet sealer:
Bob and Nancy
Old 01-13-2015, 09:42 AM   #79
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Love this thread!!!! Had a store credit we needed to use before it expired and didn't need any parts but I just quick looked at this thread and ordered several of the sealants we will need soon.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-03-2015, 11:44 AM   #80
1973 29' Ambassador
Bethany , Oklahoma
SO CONFUSING!! I'm a newbie getting ready to remove-reseal-replace a few windows that I believe are leaking. I'm leaning away from Sikaflex because BoldAdventure mentioned it was so hard to use. SO, can I use Vulkem on the windows?? I'm noticing in the list it is only mentioned for the roof? And if i DID use vulkem, what solvent should I prep with and what fluid do i use for clean up???
Aaron and Brittany
NEWBIE 30-something with a dream of finishing their first airstream remodel...please be gentle
AaronAndBrit is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Sheljef
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
insulation, sealants and leaks Pablito Interior Restoration Forum 5 04-21-2013 10:57 AM
Summary Of Full-Timing Considerations Mr.Bill Full-Timing 57 12-03-2011 09:44 PM
Sealants Captain Hank Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-31-2011 06:31 AM
