Old 02-19-2014, 09:36 PM   #15
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Added the Loctite sealants based on acstokes recommendations.
For wheel wells/underbody:
Vulkem 116
Trempro 635
Adseal Premium Quality Sealant Gray
Roof
Silkaflex 721 White
Adseal Premium Quality Sealant White
Loctite® PL® S30 Polyurethane Roof and Flashing Sealant
Windows/Trim/Rubrail
Silkaflex 221 Gray
Parbond Gray or Clear (small hand tubes)
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Small seams (between aluminum panels)
Acryl-R (small cans)
Rivet sealer
Captain Tolley's Creeping Crack Cure
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 03-10-2014, 09:22 AM   #16
TinTin's Avatar
Canmore , Alberta
Added exterior lights to group 4
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Silkaflex 221 Gray
Small seams (between aluminum panels)/Exterior Lights
Rivet sealer
Bob and Nancy
Old 10-07-2014, 03:38 PM   #17
TinTin's Avatar
Canmore , Alberta
Added Dicor to roof sealants
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Dicor self-levelling sealant
Silkaflex 221 Gray
Rivet sealer
Bob and Nancy
Old 11-15-2014, 06:52 PM   #18
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Great thread Bob, very useful for a newb.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-26-2014, 01:55 PM   #19
Swahealy's Avatar
1972 31' Sovereign
Valparaiso , Indiana
This is so helpful TinTin. Thanks so much for posting
Swahealy is offline   Reply With Quote
Old 12-04-2014, 05:42 PM   #20
TinTin's Avatar
Canmore , Alberta
(removed LocTite PLS30 from roof sealants)
Vulkem 116
Trempro 635
Roof:
Silkaflex 721 White
Windows/Trim/Rubrail:
Silkaflex 221 Gray
Small seams (between aluminum panels)/Exterior Lights:
Rivet sealer:
Bob and Nancy
Old 12-04-2014, 07:02 PM   #21
lewster's Avatar
Naples, FL , Hood River, OR
Vulkem 116
Trempro 635
Roof:
Silkaflex 721 White
Silkaflex 221 Gray
Rivet sealer:
Just a couple of comments from the 'field'.
I use cases of sealants each month. I have settled on Sika as the go to OEM as they have the best, most consistently performing product that I have used.
I use 221 in white for roof seams, 221 grey for windows, doors and general sealing on aluminum and 715, which is a silane terminated polymer (doesn't harden and crack) for major roofing seams and around protrusions like fans, vents, skylights, etc. as it is self leveling.
Dicor self leveling applies nicely, but is very high in VOCs and will start to show drying cracks within a year or 2 of outdoor exposure. I'm constantly ripping it from existing roofing on SOBs and repacing it with 715. The Airstream factory is also using SikaFlex 221 in white/grey/black on the newer trailers and Interstates.
One note of caution: the surface must be properly prepared and cleaned before applying any type of sealant. I use Eterna Bond spray cleaner prior to applying Sika products. They also make their own cleaner, but it is increasingly hard to find. DO NOT USE ALCOHOL if ytou intend to apply any Sika products.
Old 12-04-2014, 08:58 PM   #22
TinTin's Avatar
Canmore , Alberta
Thanks Lew!! Changes made according to Lewster's recommendations.
Vulkem 116
Trempro 635
Sikaflex 221 Black (use Eterna Bond spray cleaner to prepare surface)
Adseal Premium Quality Sealant Grey
Roof:
Sikaflex 221 White (for roof seams ... use Eterna Bond spray cleaner to prepare surface)
Sikaflex 715 (around fans, vents, skylights ... self-levelling)
Sikaflex 221 Grey (use Eterna-Bond spray cleaner to prepare surface)
Parbond Grey or Clear (small hand tubes)
Rivet sealer:
Captain Tolley's Creeping Crack CureParbond Gray or Clear (small hand tubes)
Bob and Nancy
Old 12-05-2014, 07:21 AM   #23
Would acetone be okay to use?
Trixella is offline   Reply With Quote
Old 12-05-2014, 08:43 AM   #24
lewster's Avatar
I have used acetone in a pinch. Saturate a rag and wipe the area where the sealant will be placed. I have also done the same with brake/carb cleaner, but always place on a rag first.
Be sure to test on a small unobtrusive space first c
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 12-05-2014, 10:04 AM   #25
2005 19' Safari
GLENDALE , AZ
Just curious; why not alcohol?
Also, what is the "active ingredient" solvent (e.g., MEK, trichloroethylene, xylene, etc.) in the EternaBond spray and Sika cleaners?
Old 12-05-2014, 10:09 AM   #26
lewster's Avatar
I haven't gone into the chemistry of the cleaners, but Sika was adamant about NOT using alcohol under any of their sealants. It affects the bonding and adhesive properties of their products.
Lew Farber
541-490-6357
Old 12-05-2014, 11:19 AM   #27
TinTin's Avatar
Canmore , Alberta
...corrected typo
Vulkem 116
Trempro 635
Roof:
Rivet sealer:
Bob and Nancy
Old 12-05-2014, 05:58 PM   #28
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
This thread is awesome!! Very helpful
PharmGeek is offline   Reply With Quote
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
insulation, sealants and leaks Pablito Interior Restoration Forum 5 04-21-2013 10:57 AM
Summary Of Full-Timing Considerations Mr.Bill Full-Timing 57 12-03-2011 09:44 PM
Sealants Captain Hank Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-31-2011 06:31 AM
