08-09-2019, 09:15 AM
#241
2003 25' Safari
Keizer
, Oregon
Sikaflex 221 gray or aluminum gray?
Hi silver twinkee (with good stuff inside) comrades
It seems there are gray color choices, and because I want to start out this process on the right foot...
Should I purchase Sikaflex 221 gray? or aluminum gray?
2003 Safari 25SS
10-19-2019, 12:18 PM
#242
1978 31' Sovereign
New Smyrna Beach
What a geat thread on sealants
Kudos to TinTin for envisioning this thread and for the significant contributions from "lewster," for sharing his significant experience.
My 78 Sovereign has many leak issues I working through, but my question relates to the proper way to install and apply sealant to an aluminum patch. I have two patches to install, one on the roof to cover the hole left from on old corroded TV antenna, and I want to eliminate the internal battery compartment and replace the old door with a patch.
One application is on the roof. One application is on the front (side). How should the sealants be applied (probably will use Sika products) both on the inside and the outside of the patch?
What would be most helpful to me is understanding the process once the patch is made and ready to install? For example, do you put sealant between the patch and the skin? In the case of the roof, so you use a self leveling caulk on all the rivets and around the edges of the patch? How do you seal up the interior side of the patch, or is that necessary?
Would really appreciate your input.
10-21-2019, 08:31 AM
#243
1981 31' Excella II
New Market
, Alabama
Recent observations using Trempro 635 and Parbond. The Trempro shrinks and cracks over time and it tends to have poor adhesive strength and not great tensile strength. It does ok where you have a really thick fillet joint 1/4" or bigger or a flange where it is applied between the two flanges. It does not like movement like on an awning bracket and it does not do well with narrow cracks. The Parbond seems to have better properties and it is a much stronger adhesive. It gets a crust on it eventually and falls apart but up to that point it performs well. The Parbond has better elongation so it does not crack as bad in shifting areas. Probably best to use several layers of this stuff since the top layer can get crusty after several years. These are observations in the 5-10 yr range. I bought my trailer in 2011 and have done a lot of work on it over the years. So consider this a long term test. I will post some before and after photos around some windows where I used Trempro as soon as I get a chance.
Perry
06-29-2020, 05:43 PM
#244
2000 30' Excella
GTA
, Ontario
Originally Posted by TinTin
I've been reviewing the forums to determine which sealants to buy for water-sealing maintenance on my new-to-me Airstream. I've come up with the following list of sealants from the posts of others. If anyone has suggestions regarding these sealants, suggestions for better products, or sources for these products, I'd really like to hear them!!
For wheel wells/underbody:
Vulkem 116
Trempro 635
Roof
Silkaflex 721 White
Windows/Trim
Silkaflex 221 Gray
Parbond Gray or Clear
Small seams (between aluminum panels)
Acryl-R
Hi Gang is this list still good to use
#4286 Stella the 2000 30ft Excella/Classic - Tow Vehicle - 2020 GMC Denali 1500 Duramax 3.0l Diesel, ProPride3 WDH.
previous tow vehicles 2012 Mercedes Benz GL350d - CanAmRv.ca hitch Reinforcement, 2005 Ford F150 Lariat 5.4L
06-30-2020, 07:03 AM
#245
1978 31' Sovereign
New Smyrna Beach
Yes, although I find parking to be difficult to work with because it can’t be “tooled” after it has been applied. Sikaflex is better
06-30-2020, 09:08 AM
#246
KW
, Ontario
I prefer the dymonic 100 over the Vulcem 116.
Much easier to tool.
07-07-2020, 10:50 AM
#247
2020 30' Flying Cloud
Katy
Caulk/Adhesive
I'm having to replace a skylight. Do the caulks mentioned for Windows/Trim apply to the skylight?
07-08-2020, 05:13 AM
#248
1978 31' Sovereign
New Smyrna Beach
If it’s mounted to the roof, you should be using a self leveling caulk like Dicor or Sikaflex
07-10-2020, 01:00 PM
#249
Katy
Thanks, when you say Sikaflex I assume you are referring to 221. As near as I can tell 721 doesn't seem to exist anymore.
Best regards,
Dan
07-11-2020, 05:58 AM
#250
1978 31' Sovereign
New Smyrna Beach
Dan - I was referring to 721. 221 is not self leveling.
I had to patch some holes in the roof of my Sovereign where I removed one of my ceiling vents. Between the patch and the roof I used 221 and when all the bucked rivets were installed I cleaned up around the edges with mineral spirits. Then I went over the edges of the patch with Dicor self-leveling caulk. I also used Dicor around a new MaxxAir vent and new TV antenna.
Hope this helps
07-11-2020, 07:33 AM
#251
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
I have used 3M 4200 and covered with Extreme Sealing tape, 8 years plus...SFSG 👍
07-12-2020, 02:09 PM
#252
2000 30' Excella
GTA
, Ontario
Originally Posted by ROBERT CROSS
Hi Bob
In your picture of the roof vent it appears to be just the tape? Or did you use the sealant under the flange and then tape on top....
I think I answered my own question.
That tape is expensive (shipped to the great white North)
07-12-2020, 03:07 PM
#253
2015 23' Flying Cloud
Copper Hill
, Virginia
Hey Bob, I followed one of your earlier postS and you didn’t mention the 3M 4200. I cleaned mine with braklean then just used the tape. Should I redo or just leave it be with just the tape.
07-12-2020, 05:13 PM
#254
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Just leave it...if the original is not compromised the tape will protect it very well.
That is what I did with my original skylight, 'til it cracked and had to be replaced anyway.
07-12-2020, 09:11 PM
#255
2015 25' FB International
AGREED! You snuck that 3M 4200 caveat in here much later, Bob. I'm getting a water leak by the door; happened once before and incorrectly assumed it was condensation from the over zealous ducted AC vent + door my wife and kid can never seem to fully close. It's apparent though now in major rainfall, it's NOT condensation. I'm thinking it's coming from the less than fantastic, Fantastic Roof Vent. Minor cracking at the flange, but caulking is falling apart... may just clean and use "Bob's crazy tape" for a fix.
07-13-2020, 05:14 AM
#256
Katy
Purchased from Amazon???
Hi Bob, did you purchase this from Amazon? Reviews there are indicating some problems with delivery of the desired product. The 3M 4200 is showing up without the nozzle, damaged, or partially cured.
The Extreme Sealing tape is being called out as fake, not the actual 3M product. The tape is not one continuous length and the cardboard core doesn't have the 3M brand on it.
07-13-2020, 05:22 AM
#257
2012 25' FB International
Trent Woods
, North Carolina
I get my supplies like this from McMaster.com. But, there are many sellers of 3M tape that repackage the tape in smaller rolls so that you will not see 3M on the cardboard. I really do not know how to verify whether it is 3M or not, but I know the stuff I buy from McMaster always works like it supposed to.
Larry
07-22-2020, 07:04 PM
#258
Katy
Clear Gorilla Tape
Has anyone done any research comparing Clear Gorilla Tape to the 3M 4412N tape? The reviews for Gorilla tape are very good and the cost savings would be substantial.
07-22-2020, 09:25 PM
#259
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
A quick review of the Gorilla and 3M web sites shows some substantial differences/unknowns:
Thickness:
Gorilla - unknown
3M - 0.080 inch
Release Liner:
Gorilla - No
3M - Yes
Service Temperature:
Gorilla - 140F
3M - 200F
And I'll add the following anecdotal/editorial...
Seat of the Pants Factor:
Gorilla: very good, better than most
3M - world class industrial adhesive manufacturer
The Gorilla product looks interesting and I may put some in my toolbox for various uses. After doing some research on the 3M product a few days ago I think I'm adding it to my toolbox for long-term sealing jobs that I don't want to do again for several years.
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
07-23-2020, 05:32 AM
#260
Katy
Thickness:
Gorilla - unknown
3M - 0.080 inch
Release Liner:
Gorilla - No
3M - Yes
Gorilla - 140F
3M - 200F
Thanks for your reply. On the Amazon product page I found that the thickness is .18 mm or .007 inches which is very significant, if it's correct.
