Old 10-29-2017, 04:55 PM   #201
1970 25' Caravanner
Incline Village , Nevada
Sikaflex pricing and amount needed
Great thread. I found Lewster to be a reliable source for these sealing inquiries. To reiterate his advice to me...
--Acryl-R (can with applicator, not caulk tube) for all side panel seams, rivets and rub rails.
--Sikaflex 221 for basically everything else. So I will be using it around windows, exterior lights, window glass to the frame, wheel wells, over any flanges, panel seams and rivets from inside.
--He also mentioned in this thread using Sikaflex 715 along the roof.
If sealing everything, he says (6) 10 ounce tubes of Sikaflex 221 and 1 large can of Acryl-R should be enough.
I priced out today and found Amazon to be cheapest for the Sikaflex products at around $9 per tube. (Home Depot sells a Sika product for cheaper but Lewster says this is not the right product!) Out of Doors Mart was the only place I could find the can of Acryl-R with applicator (each $34.95).
Jeremy9107 is offline   Reply With Quote
Old 12-09-2017, 11:25 AM   #202
wilmington , Delaware
permenent seal companies
I may have missed the post but what experiences has anyone had with Armor Roof Seal? I think that is one of the permanent roof companies with lifetime warranties??? THANKS in advance!
weather command is offline   Reply With Quote
Old 05-18-2018, 03:20 PM   #203
MontyV's Avatar
1994 34' Limited
Salem , Oregon
so this thread was talking about sikaflex 721, now i see reference to 221. but they are different aren't they? is 221 suitable?
MontyV is offline   Reply With Quote
Old 05-18-2018, 04:51 PM   #204
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I've used 221. I am not familiar with 721.
I usually buy Sikaflex 221 in aluminum/gray color but I've also used white depending on the application. The Sika web site indicates 221 is a non-sag, polyurethane sealant/adhesive. Non-sag means it requires "tooling" to put it where you want it at the thickness you want it. Many RV sealants are self-leveling but Sika 221 is definitely thick and needs to be shaped during and after application. I use a terrycloth rag soaked in mineral spirits to shape the mound of Sika 221 to the desired thickness.
My experience is limited and I may be applying 221 incorrectly but it seems to work. I've seen the Airstream factory repair shop using 221 and they also use a rag soaked in mineral spirits to shape the material to its final thickness.
The last time I purchased 221 I bought it from a local (non-Airstream) RV dealer. I've also purchased it from a local building supply company. Home Depot and Lowe's do not carry 221 in my area so I found a specialty, pseudo-wholesale building supply company - they are clearly the least expensive for me at around $7.50 per tube but they have limited hours compared to the RV dealer who sells their 221 for about $12 per tube.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 05-19-2018, 07:30 AM   #205
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Sikaflex 221 is my sealant of choice for most things. $10 a tube on Amazon.
TheGreatleys is offline   Reply With Quote
Old 09-28-2018, 01:36 PM   #206
2016 23' International
Newhall , California
Caulk tube seal
Originally Posted by TinTin View Post
I'm adding to the above list of sealants, based on the thread by sailorii which mentioned that Airstream now recommends AdSeal products.
For wheel wells/underbody:
Vulkem 116
Trempro 635
Adseal Premium Quality Sealant Gray (neutral silicone based)
Roof
Silkaflex 721 White
Adseal Premium Quality Sealant White (neutral silicone based)
Windows/Trim/Rubrail
Silkaflex 221 Gray
Parbond Gray or Clear (small hand tubes)
Small seams (between aluminum panels)
Acryl-R (small cans)
Sir
I like the list of sealants. Having tried many ways to seal an open caulk tube
Which do not work for a long period of time, have you found a effective
Method or device that will seal a open caulk tube for a lone period of time?
Robert
Robert12 is offline   Reply With Quote
Old 09-30-2018, 07:56 PM   #207
CruizinDux's Avatar
Tracktown USA , Oregon
Originally Posted by Robert12 View Post
Sir
Robert
This from an old neighbor ...
Not really a reseal but possibly a re-use method....plus some other suggestions in the comments section
bob
CruizinDux is offline   Reply With Quote
Old 10-01-2018, 04:29 AM   #208
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Great! Thanks for sharing. John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 12-09-2018, 09:06 PM   #209
1970 27' Overlander
McKinney , Texas
Has anyone used the “As seen on Sharktank” Flexseal product? One can buy it from HD or Lowe’s..
Airwalla is offline   Reply With Quote
Old 12-09-2018, 09:14 PM   #210
1974 27' Overlander
Yeah. Saw it on TV. They paint a screen door with it in a commercial and use it for a canoe bottom. I see someone at least once a month saying they're going to use it to coat the inside of the Airstream skin with it so it'll never leak again. Famous last words.
A sealant is only as good as its bond with the substrate and ... well ... there are much better products available.
Old 12-12-2018, 10:33 AM   #211
1988 34' Limited
jupiter , Florida
Captain Tolley's
My dad is a veteran yachtsman and swears by Captain Tolley's for all sealing on his boat.
We have to seal the wing windows (original seal is brittle and coming out) and I am researching what to use to repair it. According to this thread, the answer is the Sikaflex 221.
Why wouldn't Captain Tolley's be a good option for the windows?
Thanks in advance.
jenhansen is offline   Reply With Quote
Old 12-12-2018, 11:31 AM   #212
1974 27' Overlander
Thanks in advance.
Captain Tolley's is super thin in consistency. It's great for wicking into little cracks and holes, or around leaky rivets, but it won't make a bead, so it's not good for resealing windows. SikaFlex 221 is fantastic for making a bead around windows, doors, and vents.
Old 12-19-2018, 07:08 PM   #213
2005 16' International CCD
LAFAYETTE , Colorado
Glue for vinyl on bumper rail
What adhesive should I use to glue the decorative vinyl strip back on the bumper guard rail that I removed checking for leaks?
2006 Bambi 16"
TYSON PECK is offline   Reply With Quote
Old 02-09-2019, 04:29 PM   #214
1989 29' Land Yacht
St. Catharines , Ontario
What is the sealant used to seal the fridge compartment? It has more of a putty feel to it. I also found it where the gas lines go through the floor.
ktmkirby is offline   Reply With Quote
Old 02-09-2019, 04:57 PM   #215
1974 27' Overlander
Butyl tape? https://www.vintagetrailersupply.com...-p/vts-419.htm
Old 02-09-2019, 05:04 PM   #216
2007 31' Classic
Gulf Breeze , Florida
2006 Bambi 16"
I used 3m spray adhesive. #45
trumpetguy is offline   Reply With Quote
Old 02-09-2019, 05:05 PM   #217
1989 29' Land Yacht
Originally Posted by TheGreatleys View Post
Not Butyl tape, but it has that consistency. Maybe Butyl caulking.
Old 02-19-2019, 09:49 AM   #218
my3sonsdad's Avatar
1975 Argosy 26
1979 30' Argosy
Vienna , VIRGINIA
I am adding a window where one didn’t previously exist. The donor window frame I removed looked like it had butyl tape between the exterior skin and the window frame, so I planned to use $14 RV buytl tape from amazon along with sikaflex 221. Any alternative recommendations?
1975 Argosy 26
1979 Argosy 30
2015 Jeep GC Summit EcoDiesel w/Hensley
my3sonsdad is offline   Reply With Quote
Old 04-12-2019, 04:34 AM   #219
Sometime , Alabama
Sikaflex 221 or Sikaflex 221 "Technique"?
Amazon offers two different labeled cartridges for the 721:
Sikaflex 221
-and-
What is the difference between the two products?
Is one preferred over the other?
Thanks!
bigcountry is offline   Reply With Quote
Old 04-12-2019, 05:19 AM   #220
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Sikaflex 221
-and-
Thanks!
I have used both and can’t tell a difference. The Sika-flex website does not list the “technique” as a type like they do “LOT” or “LONG OPEN TIME”
I think it’s just a branding term.
Oh No, Marathon issue! Bruce B Tires 158 11-08-2013 02:37 PM
insulation, sealants and leaks Pablito Interior Restoration Forum 5 04-21-2013 10:57 AM
Summary Of Full-Timing Considerations Mr.Bill Full-Timing 57 12-03-2011 09:44 PM
Sealants Captain Hank Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-31-2011 06:31 AM
