Old 09-23-2014, 06:57 PM   #1
Sealant types and uses
Ok, I've read numerous threads about sealants. I'm looking to seal around marker lights, rivets, vents, etc. I'm looking to seal it up for winter. I am going to strip the clear coat off in the spring, so I took lights off and stripped under lights but will need to seal screws and wire holes. I'd like to use a sealant that I'll be able to use for other exterior seals. Vulcum? RTV? etc? What's the best seal on aluminum? This is my first Airstream. BTW its a 69 Sovereign.
tcoffee is offline   Reply With Quote
Old 09-23-2014, 07:34 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
There's a list of Airstream sealants in this thread. Go to the end of the thread for the most complete list.
http://www.airforums.com/forums/f44/...ry-116214.html
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 09-23-2014, 07:37 PM   #3
Thanks so much!!!
Tom
Old 09-23-2014, 07:40 PM   #4
2015 23' International
Charleston , South Carolina
The knowledge and willingness to share on this forum is awesome. I have subscribed to about a hundred threads for ready reference when I need them. Thanks to all.
Steve
FollySteve is offline   Reply With Quote
Old 09-23-2014, 08:18 PM   #5
r carl's Avatar
Lin , Ne
Airstream Articles: Vulkem Sealer Notice
Old 09-23-2014, 08:42 PM   #6
Great info from incredible people that have patience for a newb like me. You all will be a part of the restoration of a 69 sovereign. Thanks again and I'm sure more questions to come.
Tom
Old 09-25-2014, 12:53 PM   #7
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
weatherproofing questions
Got rain for the first time after removing all my interior skins. Water coming in from various places mainly around the windows. Spent considerable time and effort yesterday cleaning the seams between the rain guards above the windows and re-caulking with Vulkem 116. Heard more rain last night at 4am and went to check. Some improvement but still lots of water. Here's my questions:
1. I see Vulkem 116 is only listed for "wheel wells and underbelly". Should I not have used it to seal the tops of the rain guards?
2. Last night I could see water seeping in through the seams of the exterior. From the outside I can see the seams were caulked with something at one point but it's just a thin crusty remnant now. What should I use to go over the exterior seams? The stuff listed for roofs? Or the stuff listed for small seams/aluminum panels? (Acryl-R). Should I do anything on the inside?
3. The plastic window gaskets are all shrunk on my windows. Sounds like new gasket material is available but I've read it's a hassle to work with and it doesn't seem like it would be very water proof. Are there other approaches to sealing up these windows? Preferable with stuff I can score at Home Depot?
Thanks in advance,
--Jason
Sealant list from other thread:
For wheel wells/underbody:
Vulkem 116
Trempro 635
Adseal Premium Quality Sealant Gray
Roof
Silkaflex 721 White
Adseal Premium Quality Sealant White
Loctite® PL® S30 Polyurethane Roof and Flashing Sealant
Windows/Trim/Rubrail
Silkaflex 221 Gray
Parbond Gray or Clear (small hand tubes)
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Small seams (between aluminum panels)
Acryl-R (small cans)
Rivet sealer
Captain Tolley's Creeping Crack Cure
Name:	water seeping in through seams.jpg
ID:	222840   Click image for larger version
Airwave503 is offline   Reply With Quote
Old 09-25-2014, 03:38 PM   #8
TinTin's Avatar
Canmore , Alberta
I'm far from expert on this, but I think that many use Parbond around windows etc. A little easier to use, easier to apply a smallish bead, and Parbond is colour matched to aluminum.
Acryl-R is good for between seams because you can put on an exceptionally thin bead with the applicator. Parbond will work on seams as well, if you work it into the seam with a solvent soaked rag. Captain Tolley's may work too, but I've never used this.
Bob and Nancy
sealant types Pablito Leaks - Weatherstrips, Gaskets, Caulks & Sealants 18 06-13-2013 08:37 PM
uses and limitations of old solar panel system? Jenniflow Generators & Solar Power 12 08-02-2012 11:14 PM
Looking for a Unit that uses e-mail voting and paypal ronstory WBCCI Forum 8 08-26-2008 11:50 AM
Sealant Uses bsherman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 12-09-2005 07:44 PM
KLM and other types of 'Resort Packages' JodynJeep On The Road... 11 10-18-2003 12:11 AM
