Old 04-21-2014, 11:25 AM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Sealant for a small job
I have read and read and read here on the forum about sealants. I think I have some idea of what NOT to use. I have a small job to do. Specifically I need to replace a few rivets ( maybe 6 or so ). It seems that the recommended procedure suggests that we put a small bit of sealant on the rivet and squeezing out the excess upon installation. If I was incorporating this into a larger sealing job it would make it somewhat easier but I'm looking for a sealer that is appropriate to our AS trailers and comes in a smaller quantity. I have a few tubes to use on larger applications but I hesitate to puncture them for such a small need and risk wasting the rest before I will be using it.
So I'm looking for something commonly available that I can use on these few rivets. Otherwise I will need to look closer for a larger job to make it worth using a tube or 2.
Thanks, See ya on the road sometime.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-21-2014, 11:59 AM   #2
dznf0g's Avatar
Oswego , Illinois
I'd use tempro 365. You can wrap the open end with seran wrap and a rubber band, put in the freezer and it will last over a year. Do it as a practice.
Sent from my XT907 using Airstream Forums mobile app
-Rich-
Old 04-21-2014, 12:29 PM   #3
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
I'd use tempro 365.
Didn't you mean Trempro 635?
Fred Stokes
RV Rearview Camera Systems, LLC
WBCCI #2810
acstokes is offline   Reply With Quote
Old 04-21-2014, 12:33 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Alcoa Gutter Seal in silver is great for small jobs. I have a tube in the trailer that is several years old. Last week I had a small leak around a rivet on the fridge vent. I found the gutter seal and it was fine, squeezed right out and fixed the problem. Steve at VTS has it in silver: Aluminum Pigmented Gutterseal
On preserving the big tubes, I've had good luck with a couple of ways to seal the end. One way is to use the foil aluminum tape like HVAC folks use on duct work. I keep a big roll in the trailer and it is fantatic for lots of uses (one use is to put a small piece on the lower corners of the rear hatch every time I travel. It is almost invisible and is a safeguard preventing the rear hatch ever coming loose). A bit tape over the end of the tube will keep the vulkem fresh for a few weeks. For longer storage time, a big blob of hot glue over the cut end of the tube and storage in the freezer will keep it fresh for a long time.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 04-21-2014, 03:54 PM   #5
dznf0g's Avatar
Oswego , Illinois
Ha, yes, it just seems like I use it "365".
-Rich-
Old 04-21-2014, 04:52 PM   #6
cameront120's Avatar
1972 25' Tradewind
I just use a regular big tube and, as mentioned upstream, put the unused portion in the freezer (I put mine in a ziplock bag with all the air sucked out).
North Vancouver, BC
Old 04-21-2014, 05:36 PM   #7
retired USA/USAF
2001 30' Excella
Since there doesn't seem to be any suggestions of products other than those we already know about this will, I guess, be the chosen method.
Thanks all
Roger in NJ
TAC - NJ 18
Old 04-21-2014, 07:20 PM   #8
1972 25' Tradewind
Sorry, but I figured I would rather spend money on a regular sized tube of sealant and throw the leftovers in the freezer than spend a lot of time trying to find and track down an alternative in a smaller size. Life's too short for that sort of thing.
North Vancouver, BC
Time to fix the PO's sorry roof sealant job! blackhawksid General Repair Forum 9 10-06-2013 03:29 PM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
Now this is a BAD repair job! ViewRVs Ribs, Skins & Rivets 6 12-30-2003 09:41 PM
Take this job and shove..... zduke4x Off Topic Forum 9 10-11-2003 07:02 PM
