Old 07-28-2008, 10:30 PM   #1
Jephellis's Avatar
1959 18' "Footer"
Carbondale , Colorado
Images: 48
Seal seams, then polish? (59 18'er)
Hi All!
I've read a thousand threads, well maybe 5, don't have the greatest attention span so had to stop. That said, sorry for posting a "new" thread about an old heavily threaded topic.........
We have a '59 18-footer, the sealant at the seams is cracking and flaking off, also noticing moisture migration inside on the ceiling mostly. Have heard all about Vulkem and plan to use the seringe technique to seal the seams, especially on the top to keep the water/moisture from wicking in.
We plan to polish the little cutie and want to know if we should seal first or wait untill after polishing? Also is Vulkem the product for the seams or is it more appropriate for thicker applications as with window seals etc...?
Thanks ya'll!
Jeph
P.S. Colorado (we're at 6,200 ft elevation) is one of the harshest climates for the sun/dry/cold combonation, any special consideration to be made with that in mind?
Jephellis is offline   Reply With Quote
Old 07-29-2008, 03:46 AM   #2
Baltimore , Maryland
I recommend Acryl-R for seam sealing. You can get it from Airstream directly. It has a pump and a fine tipped applicator. The stuff is silver and pulls into the seam very well. I did mine after the polishing.
59 18'er Cabinet refurb Jephellis General Interior Topics 1 07-13-2008 10:09 PM
Need help w/ Re-plumbing sink in '59 18'er Jephellis Plumbing - Systems & Fixtures 2 07-08-2008 08:30 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
Parbond or Gutter Seal for Exterior Seams??? mwmoss Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 02-23-2005 08:36 AM
