Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 01-03-2008, 10:22 PM   #1
colin57
Profile:  1967 20' Globetrotter
sacramento , California
rotten floor by door
hI all, newbie here ,I replaced my 67 globetrotter with a 69 overlander & a 70 overlander .Bought the 70 before selling the 67,& then found the 69 after selling the 67.Anyhoo both trailers have rotted floors by the doors .Ive heard certain years are prone to leaks in particular places .Anyone know if this is true & if so what is the likely source of the leak.Door gasket,trim above the door?.Thanks for any insight.Ian
colin57 is offline   Reply With Quote
Old 01-03-2008, 10:32 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Warped doors and/or bad door gaskets.
That applies to any year.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 01-05-2008, 09:20 AM   #3
colin57
After peeling away the wood by the floor I discovered there is a lot of expandable foam between the belly & the floor.Is this normal? I also discovered the inside panel of the step has rotted away ,exposing the underside of the floor .I can see the foam from this hole so I have a feeling the po didnt or couldnt fix the side & so sprayed the expanding foam in to fil the void.When I repair the floor do I have to make sure the foam is replaced for insulation purposes,I,m assuming some kind of insulation was put in place when built.Thanks Ian
Last edited by azflycaster; 01-05-2008 at 10:05 AM.. Reason: Changed to std font & size
Old 01-05-2008, 10:17 AM   #4
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Hello Ian. You're completely right that the foam was added by the po. Originally 2" or so fiberglass was laid over the frame and the floor was attached. This compressed the insulation at every frame contact. There obviously is little insulation value to this. Insulation on the walls and ceiling are going to do more for interior comfort but 2" isn't much and the ribs all conduct heat/cold to the interior skin. Aluminum is a better conductor than most anything except precious metals -- better than copper and iron. The cumulative effect of floor insulation is low but provides a little protection if pipes are attached to the floor as in my '74 Argosy. I don't think you'll notice any benefit from insulating under this small section of floor. I did use stainless staples and some fiberglass batt when I had my Argosy belly skin off.
Newbie needs advice on fixing rotten floor Lyvettely Repairing/Replacing Floor &/or Frame 5 02-02-2008 01:30 PM
What to do about my rotten floor??? utahredrock Repairing/Replacing Floor &/or Frame 13 06-17-2007 03:44 PM
wet floor at door jim.bailey@e Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 09-06-2006 03:23 PM
What to do? Rotten floor cbl3030 Repairing/Replacing Floor &/or Frame 13 08-24-2006 01:25 PM
Rotten floor BurnBound Repairing/Replacing Floor &/or Frame 16 02-05-2006 09:03 PM
