Old 07-14-2010, 09:11 AM   #1
wheelerimage's Avatar
1965 20' Globetrotter
1955 22' Safari
Butte , Montana
Images: 8
Roof vent leak
An RV service place sealed the seams around my roof vents with a white material that I believe is good for most RVs. After a year, I am starting to get some leaking there. I added some Silicone which stopped the leaks.
I have since learned that silicone doesent work on aluminum and that I should have used Vulkem. I also sealed my fridge vent with silicone.
Can I put Vulkem over these other materials, or do I need to strip the old sealant first?
wheelerimage is offline   Reply With Quote
Old 07-14-2010, 09:23 AM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Remove the silicone. Vintage Trailer Supply has a Silicone Caulk Remover. I bought a small tube instead of the large one for use with a caulking gun. It works but it is still work getting the silicone off. Then you can get Vulkem to adhere properly.
Vaughan
Old 07-14-2010, 11:11 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Yes, remove the silicone. Vulkum will not adhere to silicone. Actually, I'm not sure vulkum will adhere to the white stuff either. I'd do a test.
Old 07-14-2010, 12:19 PM   #4
1983 34' Excella
1967 24' Tradewind
Images: 32
Originally Posted by Minno View Post
...Actually, I'm not sure vulkum will adhere to the white stuff either. I'd do a test.
Good point. Clean surfaces are best for just about everything. True for paint and sealers, prep is the most important part.
Vaughan
Old 07-14-2010, 03:23 PM   #5
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
forgive the question here but... why does silicone not work on aluminum?
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 07-14-2010, 04:05 PM   #6
Minno's Avatar
1972 31' Sovereign
Silicone will EAT aluminum over time. We removed a TV antennae from our Little Girl that had been sealed with silicone years ago. The aluminum had corroded and thinned out to the point that we had to patch it.
Kay
Old 11-14-2011, 08:44 AM   #7
1983 31' Excella
2005 30' Classic
1993 33' Land Yacht
Wellfleet , Massachusetts
Does anyone used Kool Seal to paint around the vents to seal them I use to use them on my old camper on the seams and it seamed to work well but I don't hear it mentioned any more ?
Don
Don.44 is offline   Reply With Quote
Old 11-14-2011, 09:27 AM   #8
Don
Use Vulkem or Sikoflex, "ONLY".
Use what is known to work, instead of guessing.
Old 11-14-2011, 10:56 AM   #9
blickcd's Avatar
Milford , Ohio
How about Parbond? I've always heard that was okay too, and it works well.
Christopher
blickcd is offline   Reply With Quote
Old 11-14-2011, 11:58 AM   #10
1972 25' Tradewind
Madison , Wisconsin
Seal
Parabond is a bit stiff for that area. Sikaflex221 or the 3M butyl salnts will flow into the seam. Vulkem doesn't flow much, but it seems to work on almost any metal sealing job. Andy gave good advice fir roof vents. Stiff areas such as by windows and so forth Parabond does well. Some use Dicor, I have no experience with Dicor. take your time, butyl sealants can be a bit unforgiving and it takes a bit to clean up smears and so forth.
When I installed my Fantastick vents I used Sikaflex. A week or two later I put a bead of Vulkem over the Sikaflex as it wicked in really good and I wanted an exterior bead to smooth the seal off.
Smokin Camel is offline   Reply With Quote
Old 11-14-2011, 12:39 PM   #11
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I did use Kool Seal (Kool Seal® Premium White Elastomeric Roof Coat) around the Fantastic Fan to repair a leak that was allowing water to enter and dripping inside. However, I masked the metal so that I was only applying it over the existing white sealer, which was somewhat cracked. It seems to have done a good job in filling in the cracks and the leaking stopped. I used a 1" paint brush and lightly painted over the existing caulking material.
I was abbout to leave on a trip and did not have the time or desire to strip off the existing caulking, pull out the fan and completly re-do it entirely.
I have not used Kool Seal directly on the metal.
Personally, I am a fan of Kool Seal.
Steamy1 is offline   Reply With Quote
Old 11-14-2011, 01:08 PM   #12
Mexray's Avatar
1978 28' Ambassador
Morada , California
I've also used EternaBond 'tape' for a quick fix - even got it with alum on top for good match with the alum roof skin... It works best when the roof is warm so the sticky stuff can flow a bit...)
Ray & Pat; Morada, CA
Old 11-14-2011, 05:19 PM   #13
1983 31' Excella
2005 30' Classic
1993 33' Land Yacht
Have you seen that stuff advertised on TV that they spray on a screen door , that covers the bottom of a boat then they go fishing ? Well that's the stuff I think we should use ... I wonder if they have it in White or Silver too ?
Don
'76 Argosy have vent pipes at roof (nicro vent install idea) BrianD. Waste Systems, Tanks & Totes 6 11-08-2014 06:28 PM
Roof Leak flyguy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-11-2009 09:31 AM
Leak at roof vent Nightwind15 Roof Vents, Skylights & Fans 3 12-27-2008 09:32 AM
Roof flange solutions for 14" x 26" Astrodome roof vent. Petethefeet Roof Vents, Skylights & Fans 46 04-30-2008 11:13 PM
