Old 06-16-2002, 07:42 AM   #1
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Roof seal
Recently, while working on my A/S I noticed that there's sealing compound all around the vents, antenna on the roof. Does anyone have knowledge as to what brand of sealing material this is and, what kind of life expectancy does this material normally have? Can you just apply the new over the old or what?
thanks.
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 06-16-2002, 07:59 AM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Vulcem was the original sealant used and is still used today. Par-Bond Grey can also be used. SikaFlex is also used in the new Airstreams to seal the panels. Alcoa Gutter seal can be used to repair panel seams.
Do not use any silicon based products. They will chemicaly react with the aluminum and turn a real nasty grey black and they do not last as long.
I would remove as much as I could. It will make for a much more professional seal. Be sure to mask of along the area you are repairing with blue painters masking tape. It will make cleanup much easier.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 06-17-2002, 04:32 PM   #3
1984 29' Sovereign
Savannah , Missouri
Roofing seal
Thanks for the info..As you've given me some choices, I'll do some research on each. I'm just thing of the areas around places like the exhaust vents. From what I can see, it looks like it's gray and, it has a spread outward from the object being sealed.
Again, thanks. BTW , I just came back from Vt., where I visited with airstreamdreams.com
picture below is of Steve and, myself (in black hat) with his 67 A/S.
WBCCI 5292 AIR 807
NEU #64
New England Unit
Bulb Seal for 1963 Windows Alan and Mardel Windows & Screens 10 01-13-2004 12:29 PM
2004 30' Classic roof rack gklott Our Community 0 07-15-2003 04:00 PM
Roof question Don in E Texas Roof 2 02-21-2003 07:11 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 06:53 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 02:35 PM
