Old 01-18-2012, 08:53 AM   #1
Roof leaks
It's amazing, how many owners have never replaced the sewer vent pipe cover gaskets, that are known to only last 2 to 3 years.
Lack of replacement leads to a partially rotted floor.
Old 01-18-2012, 11:08 AM   #2
1981 31' Excella II
New Market , Alabama
I am doing an experiment with no gasket and Vulkem only around the pipe to roof interface. In a year I will take the cover off and inspect the Vulkem to see how it is doing. I don't like something that high maintenance but your right it needs to be taken care of. I had a pretty good size leak in the rear of my center bath and fixing the vent seems to have fixed the leak. My leak ended up in the rear not in the bathroom where you would think the water would go.
Perry
Old 01-18-2012, 01:43 PM   #3
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Actually depending on your climate, they can last less than one year. I was surprised to see that the rubber was cracked pretty bad after just over 6 months on mine. I will probably change mine to a vent of different design.
SilverHoot is offline   Reply With Quote
Old 01-18-2012, 01:49 PM   #4
Perry
Perry.
The sewer vent pipes move when the trailer is towed.
After the Vulkem sets up, it more than likely will pull the seam apart.
Vulkem is strong, but I don't think it can handle the twisting of the shell.
That's why the gasket was used.
But, time will tell.
Old 01-18-2012, 01:52 PM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
6 years ago I used pond liner materiel still looks good
'77 Sovereign Intl 31' CB
Old 01-18-2012, 02:06 PM   #6
Airstream uses, at least in their opinion, materials and parts that are normally better than average.
What to use when repairing an Airstream product, such as the way it was built, may not always be the best to use, but it sure is a good starting point, at least until that method or part has been adequately proved wrong or inadequate.
Remember, that the shell lasts forever, and not much else.
Old 01-18-2012, 02:44 PM   #7
x
XXXX , XXXX
My sewer pipe gaskets must have been made from some exceptional material. When I tore down the trailer there was absolutely no evidence that they ever leaked. No rotting of the floor, no staining on the inside of the outer shell, no staining on the inside of the inner skins, no water marks on the pipes at all.
I think the contention that they will only last 2 to 3 yrs highly suspect, but that is only my opinion of course based on my observations.
wasagachris is offline   Reply With Quote
Old 01-18-2012, 03:42 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
What our gasket looked like after 6mos on the dealer lot....
Lucky I was Forum warned and caught it rite away.
Factory also forgot several screws so it leaked like a sieve.
Name:	SOLAR PANELS; ROOF LEAK 021.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-18-2012, 05:11 PM   #9
Cyclist
henw's Avatar
2007 28' International CCD
Windermere , Florida
Where do they leak? From the outside, or from in the pipe?
Just asking as I check the caulk for cracks routinely.
TW
2007 28' Int CCD.
2011 F 250 Big Honking Diesel
DTV 5lnb on a tripod.
Wilson wired repeater with YAG.
Two big screens
15dB Backfire WiFi antenna and WaveMagnum
Centramatics.
Hawkshead Tire Monitors.
henw is offline   Reply With Quote
Old 01-18-2012, 05:14 PM   #10
2010 27' FB Classic
N/A , Texas
Originally Posted by Inland RV Center, In View Post
Perry.
Andy are you refering to the old style aluminum shroud covers for the pipes or the new style plastic sewer vents/covers?
Old 01-18-2012, 07:38 PM   #11
TW
On our Classic.....both
You can see the pipe gasket in the above post.....
Here is the flange and base....
POI...new gasket made from inner-tube.
Name:	SOLAR PANELS; ROOF LEAK 011.jpg
PFC
"Tahawus"
RLC
John Prine
Old 01-18-2012, 07:59 PM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Bob, that flange is so far above the roof and so hideously sealed it looks like it was pulled loose and reinstalled at the dealership by an office pinkie. Do you think they could have "borrowed" the part for some reason, then put this one one later? Or something.
Another thought. Can these sewer vent pipes bind on the cover while moving down the road, and push them up?
doug k
Old 01-18-2012, 08:14 PM   #13
Doug,
No the factory just didn't see fit to install all mount screws. If I remember right there were 12 holes in the plastic flange and they only used 5 screws. Look close and you can see one empty hole.
I drilled six new holes in the roof and used 9 new stainless screws.
The pipe is not secured directly to the roof, the gasket fits over the pipe and under the flange base, there is room for it to move slightly under the hat.
PFC
"Tahawus"
RLC
John Prine
Old 01-18-2012, 09:12 PM   #14
The old style polished metal covers.
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 07:02 PM
HELP! kitchen window leaks Jcashcollect Windows & Screens 4 06-23-2011 10:41 AM
Fixing leaks on roof Rickman4 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-08-2011 05:23 PM
