Old 03-04-2011, 03:50 PM   #1
andyfuson's Avatar
2004 25' International CCD
Stone Mountain , Georgia
Roof Leak during heavy rain
I have been trying to figure out why water comes down into my bed as well as runs down the walls into the lower body section of my trailer. I noticed that the shroud on the A/C unit is busted and has a large piece missing. Can the rain enter the trailer through the A/C unit? Also, I can't seem to figure out where to order a new shroud from. Obviously it needs to be replaced either way.
Any wisdom is appreciated.
Would rather be camping!!!
andyfuson is offline   Reply With Quote
Old 03-04-2011, 04:20 PM   #2
RaleighAir's Avatar
1973 31' Sovereign
raleigh , North Carolina
Maybe AC pan drain clogged?
RaleighAir is offline   Reply With Quote
Old 03-04-2011, 05:57 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
I might suggest to get the trailer bubble tested to possibly dramatically shorten the time it takes to find the source of the leaks and repair them all. My trailer is older, but I thought I had one leak in front of the door and it turned out I had 11 separate leaks.
Old 03-04-2011, 06:23 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Original AC unit?? Camping World has a quality aftermarket shroud for the unit. Mine was about $100 and they gave me a military discount. It's a do-it-youself project.
Look at the oven side vent - that was where my leak was. Leaks on AS can be almost anywhere. After a few years, you almost have to have every outside seal redone and inspected. Good insurance.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 03-04-2011, 06:37 PM   #5
tpi
Trabuco Canyon , California
The airconditioner is most likely a Dometic Penguin. Shroud is commonly available. I got mine at camping world but google it. I see it on Amazon.
It would certainly be a good idea to replace it, perhaps it could solve the leakage.
Check the rear cabin vent, the bathroom exhaust fan, the sewer vent cap. If it were mine, I'd take a good look around on the roof.
tpi is offline   Reply With Quote
Old 03-04-2011, 06:48 PM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
andyfuson -- is your bed a rear sideways queen? Or a rear corner?
I know that our front-bed had leaks over the front windows due to the afterthought about how the factory attached the rockguard (it was due to incomplete caulking ... easily repaired in my driveway).
After the first handful of years I feel that I'd benefit from leak testing if I have any questions. Search the forums on Sealtech.
A deteriorating AC shroud would not cause interior leaks IMO...
5 meter Langford Nahanni
Old 03-05-2011, 02:18 PM   #7
andyfuson's Avatar
Thanks, It is a rear corner bed. I had put a sealant tape product (tar with silver backing) around the roof vents last summer. I have never tried to put anything on any of the seams though. It sounds like that may be something that I need to do. I was wondering about all of the rivets as well. Not sure if I should coat them as well. I hate to do anything that is not attractractive. I thought about painting the roof with a sealer type product, but I wasn't sure if that would look tacky.
Old 03-06-2011, 02:29 PM   #8
andyfuson's Avatar
Interesting
I'm in the metro Atlanta area, which received 2-3 inches of rain (generally steady or light) over the last day and a half. I went into the camper today, and I didn't see any signs of water inside.
This brings me back to my original idea. Is it possible, or likely, that with the A/C shroud badly broken and having a large hole in it, would light rain simply fall into the A/C pan and drain down the hose in comparison to a heavy rain that overflows the pan. In the case of water overflowing the pan, would it then enter the trailer?, or should it still not be able to get inside.
The unit is the original Dometic Penguin Duotherm, so I will begin looking online to get it ordered and replaced right away.
Old 03-06-2011, 02:33 PM   #9
Water can travel once it's in the ceiling.
Check the sewer vent pipe cover gaskets. They only last 2 to 3 years, or so.
Old 03-06-2011, 02:55 PM   #10
andyfuson's Avatar
Thanks Andy, I ordered the new cover from Camping World, and I will look at the vent pipe when I go up there to change the shroud.
Old 03-06-2011, 04:06 PM   #11
tpi
Seems like I read a forum post here or elsewhere recently about a leak cured by replacing the shroud. I recently had the top off mine, wish I had taken a picture. I doubt the pan is the source of the leak, but it could be from the sheet metal superstructure housing the fan, ductwork, and serving as blower motor attachment point. I'm not so sure all that is hermetically sealed.
Also check the little vent and fan in the bathroom.
Old 03-21-2011, 12:26 PM   #12
tarheelbornbred
tarheel1972's Avatar
1972 29' Ambassador
Wilmington , North Carolina
Send a message via AIM to tarheel1972
Question: When I scrape and clean the seams, what is a good product to clean and prep the surfaces. Mineral spirits? Windex? I don't want to aggravate the lacquer surface.
Where are you parked Andy? I am in Stone Mountain also, Stone Mountain Heights RV park. I am busy fixing my leaks to day and tomorrow.
John.
tarheel1972 is offline   Reply With Quote
Old 03-21-2011, 12:33 PM   #13
tarheelbornbred
1972 29' Ambassador
This part got lost from the original post:
I have the same problem and I am working on the problem now. I flipped the AC unit over (Dometic Brisk Air) and it seems that I have to improve the blocks between the inner and outer skins. This should improve the compression on the AC seal. I am alos going to scrape and caulk all joints in the area. Using Vulkem 116.
John.
2004 international, 25', leaks
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
Roof loads Sphere Guy Ribs, Skins & Rivets 6 01-07-2011 06:57 PM
Can not find Propane leak bmklawt LP Gas, Piping, Tanks & Regulators 15 01-02-2011 10:01 AM
