Old 06-07-2006, 09:23 PM   #1
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Roof Caulking
Can someone please tell me what type of caulking Airstream presently uses on the trailer's roof, around places like skylights, Fantastic Fans and such? Also, how do you apply it?
Although my trailer is only outside for a couple months in the summer, and stored inside the rest of the time, the caulking on these places on the roof of my trailer (now 2 years old) has cracked noticeably, to the extent that there are gaping holes in the caulk where water can easily get into.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 06-08-2006, 03:13 AM   #2
Post #3 at
http://www.airforums.com/forum...5-a-23089.html
and post #5 at
http://www.airforums.com/forum...ighlight=acryl-
should help.Also, using the search button for "vulkem" will keep you reading the 483 threads 'till Christmas. (2007)
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-08-2006, 06:51 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Nick,
We are of one mind on the Acryl-R. I prefer Sikaflex to Vulkem, but that is just personal preference. Polyurethane sealant is the BEST!! If you want a white sealant that is 'self leveling' similar to what the factory uses around roof vents on the new units, try Dicor Self-Leveling Roof Sealant. Use it in a frame gun, and it spreads itself around the seams nicely. It is the stuff most OEM's use on roofing seams and openings.
It might be difficult to find, but any well stocked RV supply should have it. If you can't get it, I always have it in stock.
Old 06-08-2006, 07:30 AM   #4
flyfisher's Avatar
2004 30' Classic
Lew -
Thanks. I think that Dicor is what I need to get.
John
Flyfisher
Old 06-08-2006, 12:27 PM   #5
lewster's Avatar
The pleasure is all mine!!
Caulking Kistler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-19-2003 12:32 PM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 02:13 AM
