Old 09-07-2008, 03:22 PM   #1
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Rivet Shaver Sources
Has anyone tried this type of shaver for Olympic rivets? EBay sure seems to have many available. Here is one example. And here is another.
1956Safari is offline   Reply With Quote
Old 09-07-2008, 03:30 PM   #2
Baltimore , Maryland
here is where I bought mine... Byler Rivet Supply very happy with that tool purchase. I did not try and find it cheaper, I was looking for quality. All the other tools they sell are very high quality too.
Old 09-07-2008, 03:32 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
These types of shavers are for flush riveting where the rivet is a flathead and is cut down to be level with the surface. They cut a flat surface and not a convex one like a domed rivet head. The shaver for Olympic rivets uses a special concave cutter not used by anyone else-hence the price. The proper tool has a cage to center cutter over the rivet and is spring loaded in the up position. It also has a precision depth setting so you don't cut the skin. A trailer could be flush riveted in principal, but it entails a lot of extra work because each hole needs to formed as a cone before the rivet is installed. I hope this doesn't upset you we save that for the rivets!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 09-07-2008, 03:37 PM   #4
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Thanks, I knew it was too good to be true!
Old 09-07-2008, 03:39 PM   #5
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Thanks Frank. Looks like I'm using the credit card today after all.
p.s. Would you suggest installing nameplates with rivets or screws? My old ones we're screwed on and they looked original to the coach.
Old 09-07-2008, 04:22 PM   #6
I am not sure. On my 62 they are riveted. I think Steve aka Soldiermedic has a lot of screws holding things together. If you do use screws, I suggest stainless for it will cause the least amount of dissimilar oxidation.
how about a blog? ... you are ripe for a blog.
Old 09-07-2008, 04:24 PM   #7
Also those Byler folks are super nice to deal with, They seam to enjoy helping you out. AirpartsInc is the same way....
rivet shaver
Rivet Shaver Hind-Sight Ribs, Skins & Rivets 7 10-20-2006 09:28 AM
Rivet Shaver txairstream Ribs, Skins & Rivets 13 07-18-2006 11:48 AM
Operating rivet shaver Cruiser Ribs, Skins & Rivets 5 04-11-2004 02:35 PM
Rivet Shaver Bfrank Airstream Motorhome Forums 5 05-10-2003 02:46 AM
