Old 11-16-2014, 05:22 PM   #1
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Question Right sealants on the right sections
Thanks to TinTin and his Sealants Summary thread, I think I have a good idea of which sealants to use where, but I'm still confused on a few of these, and wanted to post a visual reference Q&A for anyone who can offer feedback.
According to the thread
For wheel wells/underbody:
Vulkem 116
Trempro 635
Adseal Premium Quality Sealant Gray
Roof
Silkaflex 721 White
Adseal Premium Quality Sealant White
Dicor self-levelling sealant
Loctite® PL® S30 Polyurethane Roof and Flashing Sealant
Windows/Trim/Rubrail
Silkaflex 221 Gray
Parbond Gray or Clear (small hand tubes)
Loctite® PL® S40 Polyurethane Window Door and Siding Sealant
Small seams (between aluminum panels)/Exterior Lights
Acryl-R (small cans)
Rivet sealer
Captain Tolley's Creeping Crack Cure
Based on the above, and from my start on removing the old caulk, I'm going to use Silkaflex 221 Gray on the above my rear and front pano windows.
Should I also use it down the middles as well?
I'm going to also assume that #1 should also be Silkaflex 221 Gray.
Where I'm confused is if #2 is suppose to be Acryl-R or the Clear coat pen folks talk about.
Basically I've been wondering if these are suppose to be caulked or clear coat pen'd (I made up that term.)
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-16-2014, 05:36 PM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I really like the aluminum coloured Parbond, and have used it on the rubrails, around door and windows (your #1), on taillights and marker lights, and on the awning supports. It's a little easier to apply than the large tube caulks like Silkaflex. They can get messy and frustrating if you're not careful.
Aryl-R is pretty commonly used on the seams between sheets, and Captain Tolley on suspect rivets.
Aryl-R has been used for years by Airstream, using the generic applicator or plastic syringes you can put on very narrow bead, which is what you need for between the sheets. Unfortunately not available widely, AS store sells it.
The clear coat is sometimes applied where old clear coat had to be scraped off to allow Corrosion-X to get to filiform affected areas. So not really a caulk or 'sealant' per se.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-16-2014, 05:43 PM   #3
Nomadic , USA
I might try the Parbond in the future. At the moment, we are resealing everything for a trip this Thanksgiving. And I purchased the kit from Airstream.com - so I've got two tubes of Adseal, Silkaflex and Aryl-R.
Saddly, I discovered the Sealant thread, after I made my purchase.
Old 11-16-2014, 05:58 PM   #4
TinTin's Avatar
Canmore , Alberta
You're set with what you have! Happy caulking!
Bob and Nancy
Old 11-22-2014, 10:24 AM   #5
Nomadic , USA
HOLY #$%$ Silkaflex is the most difficult caulk I have ever ever ever ever worked with. And I've been on/off in the family construction business for over two decades and probably caulked miles and miles. Two feet and it's the most frustratingly horrible caulk ever. Flows terribly and if you try to spread it with the finger you just end up with the stuff everywhere making a mess. URGH.
Old 11-22-2014, 11:09 AM   #6
Nomadic , USA
Alright, here is a tip for anyone else.
While working with this crap, I kept saying to myself, this feels like working with Oil pant. Especially every time I used my wet finger and rag to wipe. Just made things worse. It was also not wiping off my hands. So I got out the mineral spirits and sure enough.
So I'll be using a rag soaked in Mineral spirits and my finger and now things are going way better.
replacing rotted floor sections on '69 Overlander jayg Repairing/Replacing Floor &/or Frame 4 10-30-2010 11:11 AM
belly pan in sections or one piece? robertel Belly Pans & Banana Wraps 6 10-20-2010 05:35 PM
Belly sections bwaysteve Belly Pans & Banana Wraps 8 04-05-2010 09:22 PM
Obvious Holes in Forum (Model & Year Sections) Sue&Von Forum Admin, News and Member Account Info 33 04-04-2004 09:57 AM
