Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-26-2014, 09:11 PM   #1
Anchorage , Alaska
Reseating and sealing window frame after replacing a skin
Doing a shell off refurbishment of a 1963 Bambi
Had to replace a skin that has a window. Taped off the seams, and used Trempro 635 to seal between the skins. The window frames seem to have a much "bulkier" material to seal the frames to the skin. Got some "tacky-tape" from the local RV parts store. However this seem a little to thick & spongey and not sure if the forces involved in buck riveting will dimple and deform the window frame without something solid behind it
When reseating a window frame, still use Trempro 635, the bulkier tacky-tape or something different all together ?
Aktundra is offline   Reply With Quote
Old 08-27-2014, 07:23 PM   #2
Mixter's Avatar
1976 27' Overlander
Dont use the tape. They were originally installed with 2 sided tape, but over the years, the tape shrinks & deteriorates. The bucked rivet is not set properly at that point and is a good place to leak.
Just scrape all that crap off, and use your vulkem/ trempro to set it back in "wet" and buck all new rivets into the wet sealant. Use enough to squeeze out and wipe of excess as necessary.
Mixter is offline   Reply With Quote
Old 08-28-2014, 12:38 PM   #3
Anchorage , Alaska
Thanks Mixter
Old 08-29-2014, 07:48 AM   #4
1981 31' Excella II
New Market , Alabama
WD40 works well for cleaning up excess Trempro. I prefer to use Gumout carb cleaner but it can be hard on some finishes but you probably don't have any finish at this point.
Perry
Sealing After Removing Inside Vista View? Paddledipper Windows, Doors, Locks & Vents 9 02-20-2015 07:17 PM
Detecting / Sealing Leaking Rivets Without Removing Inner Skin HolyRoller Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-10-2011 03:33 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
leaks-after sealing coastal me Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 10-01-2005 01:29 PM
