Old 06-10-2010, 01:20 AM   #1
MonaxLisa's Avatar
1975 31' Excella 500
undetermined , Washington
Resealing all seams?
I picked up my AS today, woo! It was a bit of a downpour and it turns out that there are a few drips inside
It's not really been maintained well and I can see that the sealant around the windows and seams is cracking if it's there at all. I'm thinking I'd better go ahead and reseal everything before I take it west to the really rainy areas. Is there any reason this isnt a good idea? Obviously I'd clean the old crumbly bits out and wash it so it was a clean surface. The guy at the AS mobile park told me to use something called Quad. I need any suggestions as I'll be living in this full time!
MonaxLisa is offline   Reply With Quote
Old 06-10-2010, 04:59 AM   #2
2vets's Avatar
1960 24' Tradewind
St. Albans , Vermont
Check out Vintage Trailer Supply online...they have all the sealants and caulks you need that are appropriate for vintage airstreams. All airstreams leak! Don't worry!
2vets is offline   Reply With Quote
Old 06-10-2010, 05:21 AM   #3
1966 20' Globetrotter
1993 34' Limited
Hugo , Minnesota
Just where were the drips you noticed?
fstuneck is offline   Reply With Quote
Old 06-10-2010, 05:32 AM   #4
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
I used Silaflex, which was suggested by the dealer, which I bought, used, did a great job, no leaks where they were before caulking. The only trouble with Silaflex it IS very messy to work with. I have worked with all kinds of caulking, by far this is tough stuff. Delutes with mineral spirits. When it seals it seals and is very flexable. I recommend it (wear gloves!).
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-10-2010, 06:34 AM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I use Vulkem to seal up my vents and windows. It's messy but less messy than Silkaflex. A few application tips can be found on my blog. Your windows can probably use new rubber gasket seals, too. Old, cracked seals can also leak. You can buy the gaskets at Vintage Trailer Supply or Inland RV. I would definately seal up your new baby before getting up to Washington State. Leaks will destroy the floor in your trailer.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-10-2010, 06:34 AM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Tremco brand Tempro 635 is the old "vulkem". VTS has it but you can also get it at a local Fastenal store. It too is messy. Tip on sealing seams, run masking tape on either side of the seam leaving a small gap, apply the Tempro into the gap and smooth with you finger. Go both ways when you run your finger over the seam to ensure the sealer is forced into all possible voids. Then as soon as you wipe your hands off, remove the tape. Don't let the sealer get hard before you remove the tape as it will leave a little ridge. Also by forcing the sealer in with your finger you wipe off most of the excess and have a neat clean looking seam. My 68 leaked like a sieve. I tried several "techniques" to apply sealer but the method described worked best for me and looks best.
Finally, when you remove the masking tape it will have sealer on it. Wear cloths you don't mind getting messed up because you will get the stuff on your clothes no matter how hard you try not to.
Old 06-10-2010, 08:10 AM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Even on my '06 there are gaps in the caulk edges where I feel there is a good seal underneath. You could go through the big investment of time and materials and still have leaks. Why not find somebody local who does Sealtech checks -- I'd certainly recommend soldiermedic if you were near St. Louis. That could save a lot of time doing what may be unnecessary caulking and point you exactly to areas that need your attention. I'm not sure I'd be happy with an SOB RV place claiming they can work on an Airstream. I'd ask to be present during the test and probably would want to do the sealing myself anyway.
The main caulk they use at the factory now is gray Sikaflex 221. I like it because it skins over nicely in half a day. Acryl-R is a thin liquid sealer that is used for skin laps.
Applying some 2air' search secrets...
http://www.airforums.com/forums/f456...tle-59104.html
http://www.airforums.com/forums/f456...aks-56283.html
http://www.airforums.com/forums/f456...ply-32894.html
5 meter Langford Nahanni
Old 06-10-2010, 08:38 AM   #8
It's not been mentioned here -- we're giving you credit in advance for knowing that you cannot use silicone caulk on aluminum.
Old 06-10-2010, 09:24 AM   #9
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Honey it's wetter inside than outside, I know, open the door to let some water out.
Since you will be full timing I suggest redoing every seam and the windows. There is nothing more troublesome then being somewhere in a 5 day long rain spell wishing you did. This happened to me just after I thought, I really need to do some caulking, oops to late. Here is a great video working on an airstream window.
arcamedies is offline   Reply With Quote
Old 06-10-2010, 11:11 AM   #10
SpaceEgg's Avatar
1959 24' Tradewind
The Grass Capital of the World , Oregon
Quad polyurethane
Congrats on your Airstream!
When I bought mine I was told it didn't leak, and I am still chasing down the last two leaks. I hesitated when people suggested I caulk all the seams for unknown reasons, and now I wish I just went ahead and did it. You should caulk everything you can see. They're right, the water will destroy your floors and your home will smell like fungus out here in the PacNW.
The people on this site are brand loyal to Vulkem and indicate that Vintage Trailer Supply and Inland RV are places to get them. I also found Vulkem at Home Depot, available by the carton if you want to go nuts. It's about $5/sausage tube.
I opted for Quad instead as everyone there indicated it was generally accepted as a higher grade material than Vulkem. I'm a little dubious about all this since Vulkem says it's 100% polyurethane and Quad says it's 100% polyurethane. Can someone point out how they could be different?
The Quad stuff works fine, I went with the clear. I like it better than the grey. It's water-proof when dry (go figure!). My only tip is that while it skins over quickly, the Quad takes a full day to dry, and here in Oregon this spring, we haven't gone 24 hours without a sprinkle in well over a month, so a faster-drying option would have been nice.
I will continue to do the rest of the Airstream with the Quad and I will employ 68TWind's technique to keep things clean on the outside. That's a slick little trick. You might want a face-mask, polyurethane is raunchy and gives me a headache. The vapors just linger.
Good luck. You hands will soon have a steel-grip!
SpaceEgg is offline   Reply With Quote
Old 12-04-2018, 02:17 PM   #11
Whistler , British Columbia
Do you have to clean out the old seal from the seams or?... What is your prep process?
TylerG is offline   Reply With Quote
Old 12-04-2018, 04:34 PM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
A lot of progress has been made in 10yrs...research the new stuff.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 12-04-2018, 10:22 PM   #13
1971 27' Overlander
Kansas City , Kansas
There's many posts with many views on what to use. My new favourite is Lexel which you can buy at Lowe's.
The reality is, is that all the good quality sealants everyone mentions will work. The success is in the prep work. I can't stress it enough. If you do your best at cleaning the surface, masking off the working area and getting as much sealant as you can possibly get into what you're trying to seal, you'll have success.
Shermy1987 is offline   Reply With Quote
Old 12-05-2018, 07:46 PM   #14
2009 30' Classic
a city in west GA , Georgia
Great info
I plan on starting to reseal my joints to. Don't want no leaks while on the road
Joyman is online now   Reply With Quote
Resealing windows loving-life Windows & Screens 0 07-29-2009 08:04 PM
Resealing and recaulking - before or after stripping? ronstory Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 07-21-2008 12:55 AM
Resealing Roof on MH smily General Motorhome Topics 1 02-27-2004 10:57 AM
resealing windows Happycampers Windows & Screens 8 07-17-2003 06:38 AM
Split awning seams APB Awnings 4 02-10-2003 09:34 AM
