Old 03-29-2015, 09:20 PM   #1
2016 30' Classic
Issaquah , Washington
Replacing Window Gasket
The rear window channel in my 27' front bedroom is collecting water when ever it rains. Once the channel fills the water seeps through the window latch assembly and runs down the wall and under the linoleum. I believe the problem is a bad gasket in one of the corners. I noticed the gasket is cut at a 45 degree angle and in all the corners but the problem corner the gasket pieces are "glued" together where they have been cut. I have not been able to get an answer about what to use to fasten the gasket pieces to each other. Any suggestions would be greatly appreciated.
In addition, any suggestions about what the correct window latch tension is would also be greatly appreciated.
PJohnson is offline   Reply With Quote
Old 04-01-2015, 08:47 PM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
In my old trailer I used SitkaFlex221 to fill the gap caused by shrinkage. Yours is much newer you may be able to ask an automotive window repair shop near you for help in a prettier repair. As for the window tension use just enough to keep water out your seals will be grateful with less stress on them :-)
thesignlady is offline   Reply With Quote
Old 04-01-2015, 09:16 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
3M gasket adhesive. it is black. you can replace gasket with it, too. replaced all ours that way. simple.
Peace and Blessings..
Channing
WBCCI# 30676
Replacing window gasket Vicki A. Windows & Screens 15 01-28-2018 03:19 PM
Replacing shower drain gasket patrick p Sinks, Showers & Toilets 10 04-02-2014 02:40 PM
Screen Door - Replacing Foam Gasket Utahgoldrup Doors & Locks 7 06-04-2009 02:32 PM
Replacing Nylon Window Guides - not holding window up Tom Bray Windows & Screens 5 06-16-2008 06:52 AM
replacing window gasket silverlassie Windows & Screens 4 03-07-2004 07:41 PM
