Old 10-12-2013, 08:46 PM   #1
2007 25' Safari SS SE
Marion , Iowa
Question replacing acrylar/parbond
I'm in the process of re-doing all of the seams on an '07 safari 25 ss se where acrylar or parbond is typically used. What's on there now is the original factory stuff. It was applied on the top and sides of many fixtures such as taillights, stove exhaust fan and fresh water inlet door but not the bottom. Was this just an oversight at the factory or is there a reason for this?
bangzoom is offline   Reply With Quote
Old 10-12-2013, 08:53 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
leaving the underside 'unsealed' can help in draining of water that gets 'behind' things.. remember, this is not a 'pressure vessel'... it is not capable of holding lots of air pressure like a commercial airliner. As long as the 'unsealed' area is below the cutout in the aluminum, water should drain nicely.
Since this is the fresh water fill door.. it matches my 1999 Excella.. same 'sealant' method.
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-12-2013, 09:14 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
The last thing you want to do is trap water against aluminum. It will corrode because it can't evaporate. It is very common to leave the bottom open on fixtures and probably a "best practice".
reinergirl is offline   Reply With Quote
Old 10-13-2013, 06:31 PM   #4
Marion , Iowa
Thanks Channing and Shelly for the quick response. I kind of suspected that but didn't know for sure.
